70 RR Changing throttle cable ?? #1692731
10/31/14 10:56 AM
10/31/14 10:56 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Do you have to pull the whole bracket out to change the cable are will it pull thru the firewall with out removing it? It is going to be a pain to take the bracket out because of where the bolts are.
Re: 70 RR Changing throttle cable ?? [Re: okie] #1692732
10/31/14 11:31 AM
10/31/14 11:31 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There is a little plastic pin where the cable ball attaches to the pedal bracket. Pull that out and the cable ball will then drop out of that bracket. Then there is a clip that holds the cable casing to the firewall. Remove that. Disconnect the cable from the engine and it should now be free to remove.
Re: 70 RR Changing throttle cable ?? [Re: Stanton] #1692733
10/31/14 01:45 PM
10/31/14 01:45 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
^^^^^^^^Right on the money! DON'T lost the little plastic plug at the top of the pedal assembly.
...FAFO...
