Page 1 of 3 1 2 3
Disc o tech - blues....my 4 wheel drums were better. #1692649
10/30/14 10:49 PM
10/30/14 10:49 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
Just finished off a disc conversion using..
10.9 inch rotors - new
72 ebody pin calipers - new
72 ebody spindles (w/bearing adaper) - new
1 1/32 master - new
all new lines and hoses
10 * 1/3/4 drums out back, not new but in great shape.
no combination or proportioning valve.
Brakes just suck - low but hard pedal and I gotta stand on it to stop the car..
Brakes are bled I guess - no spongy but low and hard as hell pedal.
I know a combination valve is in order but will that fix the feel of the brakes? - which year/body valve should i get? Will a generic under master cyl gm unit work?
I guess I need a residual pressure valve in the rear lines as well - will that fix the pedal height?
What steps should I take to resolve this - I don't want to just throw a bunch more variables into this system and never get it right..
Plaz
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692650
10/30/14 10:55 PM
10/30/14 10:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No mention of what type of master your using?, drum/drum?, disc/drum?, OEM?, aftermarket?
You'll need a proportioning valve...OEM or aftermarket, your choice
Power assist?, non power?
What pedal set up was used?
Are the rear drums adjusted properly? (travel)
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692651
10/30/14 11:05 PM
10/30/14 11:05 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
1 1/32 master - new
Plaz
What makes you think they will work without either valve in there?
How do you have the lines junction ed together now?
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: DAYCLONA] #1692652
10/30/14 11:07 PM
10/30/14 11:07 PM
plazomat Offline OP
plazomat  Offline OP
Thanks so much for the response..here's more info
Disc/Drum 1 1/32 unit for an 85 dippy - new parts store purchase coni seal brand
Manual - no power
Manual pedal setup that was in car since new - 4 wheel drums
Rear drums adjusted to slight drag
Only a proporting valve or a combo valve (prop/metering functions)
Just throw all parts at car or take in stages?
Plaz
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: Challenger 1] #1692653
10/30/14 11:17 PM
10/30/14 11:17 PM
plazomat Offline OP
plazomat  Offline OP
The stock drum/drum unit is in there - its just a distribution block and does not provide any valving or metering..
Plaz
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692654
10/30/14 11:22 PM
10/30/14 11:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You really didn't follow the disc-o-tech instructions, now did you.
The M/C is too larger of a diameter.
Don't be the exception.
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692655
10/30/14 11:24 PM
10/30/14 11:24 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Pad material can affect stopping ability. My 64 Polara had the lifetime autozone pads that didn't stop for anything.
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: Supercuda] #1692656
10/30/14 11:30 PM
10/30/14 11:30 PM
plazomat Offline OP
plazomat  Offline OP
Doesn't he recomend a master from a 76-8 F body? and aren't they 1 1/32? What am I missing here?
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692657
10/30/14 11:46 PM
10/30/14 11:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Manual - no power
Plaz
Feedback,...if you repeatedly pump the pedal, does it gain noticeable height?, or maintain about the same height, does maintaining depressed pedal pressure cause the pedal to slowly sink?
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: DAYCLONA] #1692658
10/31/14 01:11 AM
10/31/14 01:11 AM
plazomat Offline OP
plazomat  Offline OP
Pumping does not change pedal feel at all.
Holding pedal down hard with foot, no sinking what so ever..
Plaz
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692659
10/31/14 01:39 AM
10/31/14 01:39 AM
I think the low pedal is key & others have had to stand on the pedal (at normal height tho) with the wrong bore MC. In my case: 65 dart with 74 A discs (76-2.75 calipers) with aftermarket (ceramic? pads) and a 1&1/8 dual alum MC with adapter plate & 10" (7&1/4) rear drums and OE drum splitter (mismatched system) and it would put me in the windshield if I stood on it. I would put it up on stands have a helper spin the fronts as you work the pedal and idle it in gear & see how the rears act. Holler with any news. I'm thinking inadequate psi (line restriction somewhaere) if there is no mechanical malfunction at the corners but there is something going on/wrong with the low pedal (find/fix that). I had that exact same symptoms (height was OK tho) on the stock car from a braided line bent at too severe of an angle. EDIT Is the MC adapter plate what is making the pedal too low and post what the pedal ratio is
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: RapidRobert] #1692660
10/31/14 02:30 AM
10/31/14 02:30 AM
plazomat Offline OP
plazomat  Offline OP
Thanks for the input RR.
I was wondering about the adapter plate as well. I think its an AR engineering one with a step where the master bolts to..http://arengineering.com/products/master-cylinder-adapter-four-studs/
I will double check the lines for kinks and what not and figure out how to measure the pedal ratio..
Plaz
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692661
10/31/14 03:20 AM
10/31/14 03:20 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Maybe I missed something but I don't recall the car you are working on....In addition, there are a few mistakes I see here.
NO Diplomat came with manual brakes. The master cylinder from a Diplomat is sized for power assist.
Any disc/drum system needs an actual proportioning valve. The front calipers use a much greater volume of fluid as compared to the rear. The stock Mopar disc/drum proportioning valve held off pressure to the rear until the FRONT built up pressure. By using what is known as a "distribution block", (No metering, just a junction for the brake lines) your calipers are only getting the volume and pressure that the old front wheel cylinders received. NOT good and nowhere near enough.
I have a bunch of actual disc/drum proportioning valves that would work. The ones from mid 70s A body cars are pretty easy to find and work well. PM me if you want a screaming deal on a used Prop valve.
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: Kern Dog] #1692662
10/31/14 03:29 AM
10/31/14 03:29 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
These are often called the "Texas" valve for obvious reasons. They are the ones I mentioned from a 73-76 A body.
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: Kern Dog] #1692663
10/31/14 03:53 AM
10/31/14 03:53 AM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I would say a smaller bore master cylinder is in order. Of course the proportioning valve also. Take not that a rebuild kit and instructions for the proportioning valve is available cheap from Muscle car research online.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: doctor_mopar] #1692664
10/31/14 11:52 AM
10/31/14 11:52 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use nothing but 70C body masters.I run Ceramic pads with my pin types on the 65.Stops great and good pedal.The stock spliter will work if you use an adjustable PP valve to the rear.I use 5th Ave PP valves.Mine have been on at leats 15 years and no problems even at 120 it stops great.Rocky
Chrysler Firepower
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: plazomat] #1692665
10/31/14 02:15 PM
10/31/14 02:15 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
After reading some of your feedback, and updates as to what the actual parts are, that are involved in your swap,...IMHO if you want to retain the 2 bolt aluminum F body master, put a booster behind it, and add a proportioning valve to the system, or if manual brakes are your desired goal, then toss the F body master and adapter plate and use a 70 B body or 70-4 E body master designed for manual disc brake application, and add a proportioning valve, if you wish to try/run the B/E body masters, just say so, and I can supply you with the PN# and specs so that you can make an informed choice regarding the proper sizing/application....I'll assume this is for your 69 Coronet?
mike
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: DAYCLONA] #1692666
10/31/14 02:41 PM
10/31/14 02:41 PM
BDW Offline
BDW  Offline
Isn't the factory manual disc/drum set-up a 1 1/16" MC?
Can't imagine it would make up the problems mentioned.
Why switch back from the nicer 2- bolt set- up?
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: BDW] #1692667
10/31/14 04:48 PM
10/31/14 04:48 PM
dogdays Offline
dogdays  Offline
First things first, you need pads that actually work. Sounds like your pads aren't doing the job. They're easy and cheap to switch, unlike some of the other suggestions here.
DO the easy things first!
Less than $10 at Rockauto.
R.
Re: Disc o tech - blues....my 4 wheel drums were better. [Re: dogdays] #1692668
10/31/14 05:53 PM
10/31/14 05:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
10 buck pads cant be too good.My ceramics were 30 bucks like 8 years ago and that was shop price.They work better that the Bendix that cost more 15 years ago.Cheap pads are just that cheap period.Saw too many problems with cheap sets at the shop.Rocky
Chrysler Firepower
Page 1 of 3 1 2 3
