Page 7 of 10 1 2 5 6 7 8 9 10
Re: Why do guys race small blocks? [Re: GTX MATT] #1692110
10/31/14 05:54 PM
10/31/14 05:54 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
NA smallblock?
I'm ruined for life.
I can't even imagine trying to make anything go fast without boost.
It's a no-brainer.
Re: Why do guys race small blocks? [Re: 1320Dart] #1692111
10/31/14 06:03 PM
10/31/14 06:03 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Don't get me wrong. I'm a die hard BB guy. I'm hot well versed in the SB area. So I'm going to ask a dumb question here.....
So what is this W8 thing all about. I'm just curious
Further, (revealing my ignorance of things that are not hemis) what is an r5p7? Is that a real small block mopar based engine, or a unique NASCAR creation? I looked at some pics online, and obviously the heads are not small block Mopar. How about the rest of it?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Why do guys race small blocks? [Re: Duner] #1692112
10/31/14 06:12 PM
10/31/14 06:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
NA smallblock?
It's a no-brainer.
A lot more complexity under the hood, I like it simple and easy and a 4.25 stroke in a 360 mag block is not hard or unreliable and can easily be made fast and drivable
Re: Why do guys race small blocks? [Re: HotRodDave] #1692113
10/31/14 06:18 PM
10/31/14 06:18 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Taking an otherwise completely tame and street friendly 400 hp 360 and making 800 hp with it by adding a turbo is just too easy for me to pass up.... and the torque is KILLER. Trying to make 800hp NA would be WAAAYYYY tougher - and most likely not bery street friendly.
Re: Why do guys race small blocks? [Re: Duner] #1692114
10/31/14 06:39 PM
10/31/14 06:39 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
To me it just seems like to make a 3800 lb car run 10's was a lot cheaper and street friendly with big block. Can you really buy a new r5p7 engine for cheap? or we talking a used engine that could be shot to start with. Thats kinda a chance you take with used.
67' charger 499 RB 10.57 at 127
Re: Why do guys race small blocks? [Re: Hemi_Joel] #1692115
10/31/14 06:40 PM
10/31/14 06:40 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
ofcourse they are mopar,the p7 are just like the ancient poly heads found on the 318A engines. well kind of,almost.
Re: Why do guys race small blocks? [Re: Monte_Smith] #1692116
10/31/14 06:51 PM
10/31/14 06:51 PM
Washington
madscientist Offline
Washington
Simple answer to this question..........POWER is directly rated to air flow.......flow more air, make more power. Now the question to the question, is how much power you want to make.
If your goal is 700hp or less, either can easily do it, with the smallblock in this range only required to be slightly more exotic to achieve these numbers. And in a weight for weight car, the small motor should be quicker because of lighter engine.
If 800hp is what you want, both can still easily do it, but the big block gets more costly and the smallblock gets REALLY costly.
If 900 is your goal, this is big block land......... NOT saying a smallblock won't make 900, it will. But at that level the 900hp small motor will cost WAY more than the 900hp big block and be less reliable.
If you want a good bit over 900hp, this is big block land......PERIOD
Monte
Once again, Monte is proving why he is one of the sharpest guys around.
It really is this simple.
Re: Why do guys race small blocks? [Re: GTX MATT] #1692117
10/31/14 07:09 PM
10/31/14 07:09 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Alright, how fast can I go with an NA pump gas small block that I can run on the street with a 4 speed and 4.56s in my 3700 lb car for 7k?
Still waiting. Where'd the 7K 8 second 273 guys go?
Re: Why do guys race small blocks? [Re: GTX MATT] #1692118
10/31/14 08:16 PM
10/31/14 08:16 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
R5P7 for under 7000 and done
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Why do guys race small blocks? [Re: GTX MATT] #1692119
10/31/14 08:17 PM
10/31/14 08:17 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Too many variables to your question. You already know this, can you drive it? Will it hook and go?
Buy an R3W8 motor or an R5P7 (that would love a manual trans) for 5-7k and away you go. You can't try to add in the cost of fuel and ignition system since the big block would need that too.
There, you got an answer, I'm not going to map out an entire build.... how would you be 3700 with a SBM tho?? Sports Fury wagon?? Lol
Re: Why do guys race small blocks? [Re: SpareParts] #1692120
10/31/14 08:29 PM
10/31/14 08:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Used parts, deals and all that are just that, good deals. I'm one of the luckiest on the planet. Traded labor for the upper half, short block donated. Bought a few new parts. I saddled it down with stock eddy carbs and a cross ram. hat did I end up with? A 572 that has gone 9.12@147, 3340lbs, 10.5 tires for less than $3500. Is it a world beater? No way. Can I bracket race it with low maintenance, yes. Was I lucky to get it ,Yes Yes yes. It doesn't have.027" rings, how much are those? Headers are easy to make until the inner fenders are still there.
Doug
Re: Why do guys race small blocks? [Re: dvw] #1692121
10/31/14 08:52 PM
10/31/14 08:52 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Used parts, deals and all that are just that, good deals. I'm one of the luckiest on the planet. Traded labor for the upper half, short block donated. Bought a few new parts. I saddled it down with stock eddy carbs and a cross ram. hat did I end up with? A 572 that has gone [Email]9.12@147[/Email], 3340lbs, 10.5 tires for less than $3500. Is it a world beater? No way. Can I bracket race it with low maintenance, yes. Was I lucky to get it ,Yes Yes yes. It doesn't have.027" rings, how much are those? Headers are easy to make until the inner fenders are still there.
Doug
I've got several brand new sets with .043 rings and .927 pins. Cheap cheap cheap... Also two cranks with Chevy journals. This engine will last me a lifetime unless the block splits in half.
Let this be our little secret... Cut the flanges off w2 headers and and tweak the tubes just a touch, P7 flanges will weld right on. Don't tell any one. OK?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Why do guys race small blocks? [Re: DemonDust] #1692122
10/31/14 09:13 PM
10/31/14 09:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
How does a .043" ring fit a .027" groove? No way they run at 7000 and make power. I believe your video it looks like 8500+, am I correct? What if you want to change the cam? Nothing against the old NASCAR stuff. But I question the work required raises the costs. Also not everyone has fab skills necessary. I'm assuming dry sump, was that extra $? Oil lines? Tank? Accessory drive? How about the bell housing and converter stuff? Personally if I wasn't running a specific class ( N/SS) I would definitely consider a P-7. That being said fabrication doesn't scare me at all. How about a "total cost" to get it in the car? How many MPH has your
car run and at what weight, just curious as I know your still working on ET.
Doug
Re: Why do guys race small blocks? [Re: dvw] #1692123
10/31/14 09:22 PM
10/31/14 09:22 PM
Arizona
Chris'sBarracuda Offline
Arizona
I'm thinking Thumpers Dart dollar for dollar is the best going that I've seen..
Chris..
Re: Why do guys race small blocks? [Re: dvw] #1692124
10/31/14 10:07 PM
10/31/14 10:07 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Doug
I have several sets of pistons with .043 ring lands is what I meant. I never said that 7000 was what it made power at. $7000 is what I have in the engine itself complete. I bought all the accessories and motorplate for $1200 from EEI. I bought a complete engine in NEW parts for $3800 from John Nizamoff (PS Arrow). I bought the oil tank for $450 from Peterson. I bought a Lot of AN lines/fittings from a shop in SC for $200 (enough lines and fittings to plumb about 5 engines). Cut apart a 2 sets of damaged inconel headers (free) and made one set to fit my duster. Bought pin oilers for $75 around $300 in gaskets, $100 for aluminum freeze plug kit, $65 for one wire alt. $115 for 20AN kevlar upper radiator hose, $190 for a radiator. Had to buy some misc bolts for intake, water manifold, headers, and a dizzy hold down.
If you are willing to search around you can find awesome deals. If you want one tomorrow you may pay a little more.
I built the engine myself so, I only had $180 in finish machining on the block.
Yes, your eyes are correct 9400 rpms. All the fab was done by myself or at my buddies machine shop by me. But I thought we were just talking the price of the engine? Either way when making power you have to build a trans and buy a good converter so that point is mute.
To date the car has been 141 mph. Et is erratic due to traction/suspension issues as is the 60'.
SDG Motorsports
Re: Why do guys race small blocks? [Re: 1967dartgt] #1692125
10/31/14 10:44 PM
10/31/14 10:44 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
How fast will it go? What in it? Cam/Compression/Displacement? What block? Where do you buy the heads? Intake?
I don't know anything about them really, I would like to drink from the goblet of knowledge.
P7 are the heads and R5 is the block?
What, if anything, interchanges with an LA or Magnum engines? Fuel pump, dizzy, etc.?
Re: Why do guys race small blocks? [Re: GTX MATT] #1692126
11/01/14 12:20 AM
11/01/14 12:20 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
y
All you had to do was read the post above yours.
Re: Why do guys race small blocks? [Re: DemonDust] #1692127
11/01/14 12:43 AM
11/01/14 12:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
You did pretty decent on the accessory costs. I knew you didn't run it at 7000. Just pointing out that the RPM range on one of these motors is pretty high. The transmission question was, what special parts are required to bolt it up? I guess my point is you can't pull out a 340/360 and bolt one of these in in a weekend for 5-7K total. I love listening to it though. I'm sure you'll get the chassis hooking as well.
Doug
Re: Why do guys race small blocks? [Re: dvw] #1692128
11/01/14 12:50 AM
11/01/14 12:50 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Doug
Doug
If you add up what he has yes you can, you just need the adaptor plate that goes it a 727/904 trans and your done. I would assume sine you had a 340/360 you would already have Trans.
Re: Why do guys race small blocks? [Re: 1967dartgt] #1692129
11/01/14 12:56 AM
11/01/14 12:56 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
Is this for na motors? Or would you consider this for power adder motors too.
Doesn't matter, air flow is KING..........You are familiar with this heads up small tire stuff. Keith Berrys small block corvette, runs 4.0s with about the baddest small block twin turbo motor that can be built. He weighs 2600lbs........Dewayne Mills and several others go 4.0s with twin turbo BIG blocks. They weigh 3250lbs. Now why would that be.........because they make a TON more power, that's why
Monte
