Re: Steering wheel alinement
[Re: stumpy]
#1691678
10/28/14 04:35 PM
10/28/14 04:35 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I agrre the tie rods adjust toe and center the wheel.Some I did I had to do a few times to get a real straight wheel.Rocky
Chrysler Firepower
[Re: Michael Ecks]
#1691681
10/28/14 10:39 PM
10/28/14 10:39 PM
therocks
Niles , Ohio
Ecks you said it good.Ive seen some that were off more than that.Spec was set OK but the wheel was way off.Older cars some play is usual but it should be closer than 1/8 off.Like I said I had to do some cars more than once.Its a pain rehanging the heads but you do it to do the job right.Rocky
Chrysler Firepower
[Re: MOPARMIKE69]
#1691685
10/29/14 07:27 PM
10/29/14 07:27 PM
Posts: 4,965 WI
Dcuda69
WI
The easiest thing to do is simply file that key out of the wheel, and put the wheel on straight.
Sure just rig it instead of doing it right. Yeah file that baby out and after several hours you will have ruined the wheel and let an incompetent or just plain lazy tech get by with substandard work. Yeah that's the easiest thing to do......NOT!
You paid to have your car aligned. The FIRST thing you do is make sure the steering wheel lines up correctly. No way I would do anything but take it back and make them do it right.
I've done alignments for 30 years and would NEVER give a car back to a customer with an unlevel steering wheel! #1 customer complaint with alignments. Take it back!! Most modern equipment(such as Hunter) have a built in program to set toe AND center the wheel, all it takes is a tech willing to follow the on-screen prompts
[Re: Dcuda69]
#1691689
10/29/14 08:36 PM
10/29/14 08:36 PM
Posts: 1,324 Virginia's Eastern Shore
dmoore
Yep, that Hunter program was the brain child of Matthew "Wintoe" Winslow...
[Re: dmoore]
#1691690
10/29/14 09:52 PM
10/29/14 09:52 PM
Posts: 4,965 WI
Dcuda69
WI
Well I'd like to buy him a Works very well IF ya follow the prompts. Straight steering wheel every time!
[Re: rtjerry]
#1691692
10/30/14 01:50 AM
10/30/14 01:50 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I've become a somewhat armchair rookie tech on steering box shimming recently. Perhaps an issue is that your K member box mounting location is tweaked(perhaps accident or some such misfortune) a bit causing box to mount off center,,,,you had noted problem before all new components installed and replacing did not improve situation.
You can only go so far on tie rod adjustment before running out of threads, or having one side much longer than opposing side to center your wheel.
I don't know how you car is set up, but on E body you have basically unlimited ability to rotate steering shaft in relation to box input spline to center wheel,,,,however possibly leaving steering box off top center when wheels are dead ahead.
You might consider shimming your box a bit. See my saga under the suspension and braking forum section for more details. My issue however was not the K member, but was with the box itself.
