63 D100 Big Block Bellhousing #1691541
10/28/14 11:54 AM
10/28/14 11:54 AM
Central California
MoParFish Offline OP
Central California
Just thinkin' ahead. I have a 63 D100 short box with a decent running, but tired, Poly 318/4speed. I've been casually looking for a big block bellhousing to accept the pass side slave cylinder just like it has now. Did the big blocks have the same slave setup and are there any still out there and what years to look for? Also, will the 318 flywheel work with a steel crank 440? I'm not gonna yank the 318 till it gives me trouble, just collecting parts at this point. Thanks
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: 63 D100 Big Block Bellhousing [Re: MoParFish] #1691542
10/28/14 01:04 PM
10/28/14 01:04 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I know at least some did. I have a BB bell that came from a 68 dodge dump truck that had a 361 or 413 with the pass side cylinder. I never mocked it up against an engine, but it looks like it is used with a crank that has an extended flange, and wouldn't fit with a normal style 6 bolt crank flange...
Re: 63 D100 Big Block Bellhousing [Re: 440newport] #1691543
10/28/14 04:45 PM
10/28/14 04:45 PM
dogdays Offline
dogdays  Offline
The flywheel will work for balance and is drilled for either an 11" or 12" B&B or diaphragm pressure plate.
It's got a lot of teeth, cant remember how many but it's way more than 140.
I just had the engine out of my '64D100. I replaced the stock 11" original disk with an 11.5" Schiefer disk and 12" McLeod pressure plate that I got for next to nothing. It's something like a 2800 lb clutch and I have no problems with pedal effort, although it is noticeably harder than the original.
One other thing: When disassembling, remove the seat and the trans tunnel cover to get better access to everything. Pull the transmission first. Then, unbolt the four motor mounts and the engine and bellhousing come out together. The bellhousing weighs a ton and wraps around the flywheel, easier to take off when the engine is out. The transmission will not pull out, bolted to the engine. I found out the hard way.
R.
Re: 63 D100 Big Block Bellhousing [Re: dogdays] #1691544
10/29/14 01:31 AM
10/29/14 01:31 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Is the spline count 10 on the trans? Where can one find clutch discs and pressure plates nowadays?
JB Rhinehart, Realist
A-Body's RULE!
Re: 63 D100 Big Block Bellhousing [Re: Rhinodart] #1691545
10/29/14 01:41 PM
10/29/14 01:41 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I may have the bell housing you need...if you are going to try and keep it looking stock.....I'll try and get a part number off of it....it might be for the extended crank too...not sure.
Moparlee
Re: 63 D100 Big Block Bellhousing [Re: Rhinodart] #1691546
10/29/14 03:17 PM
10/29/14 03:17 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
http://www.hrclutch.com/
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 63 D100 Big Block Bellhousing [Re: Robbins] #1691547
10/29/14 11:16 PM
10/29/14 11:16 PM
Central California
Central California
Would keep the 4 speed. Not sure of other options on later big block bellhousings but haven't done any heavy research yet either. Extended crank??
Re: 63 D100 Big Block Bellhousing [Re: MoParFish] #1691548
10/30/14 09:36 AM
10/30/14 09:36 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
You are probably going to need the parts from a 67-68 383 truck. After that they went to a mechanical clutch. Some of the larger trucks may have used a hydraulic clutch later.
Re: 63 D100 Big Block Bellhousing [Re: Soopernaut] #1691549
10/30/14 11:18 AM
10/30/14 11:18 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Just realize that the BB truck bellhousings are only drilled for the truck transmissions, they won't work with an 833 4-speed. If you do want to use an 833...you can use a car bell but making a simple adapter bracket to put a truck hyd slave on the car bell housings to operate the clutch. There is one bell that is drilled for both truck and 833 4-speeds, but they are rare and hard to find. Look on brewers website for bell housing applications and part numbers.
Re: 63 D100 Big Block Bellhousing [Re: Quicksilver440] #1691550
10/30/14 12:29 PM
10/30/14 12:29 PM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Here is the 61-68 BB truck housing. This takes the 172T fly wheel
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 63 D100 Big Block Bellhousing [Re: moparmarks] #1691551
10/30/14 12:30 PM
10/30/14 12:30 PM
Here is the late super hard to find BB 833/435 housing
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 63 D100 Big Block Bellhousing [Re: moparmarks] #1691552
10/30/14 03:35 PM
10/30/14 03:35 PM
dogdays Offline
dogdays  Offline
Input shaft is 10 x 1 1/8" This is actually a pretty common size, a lot of chevies have this, as well as the B&B or diaphragm clutches.
You could just go straight to Centerline and buy the whole Dual Friction setup. I did it another way, cheap parts collected on the 'bay over the years. The disk was advertised as a 10 X 1 1/16, which is ford size, imagine my disappointment when it was the wrong one for that job! But it works great on the NP420.
I vote for Centerline DF if you can afford it.
R.
Re: 63 D100 Big Block Bellhousing [Re: moparmarks] #1691553
10/30/14 03:58 PM
10/30/14 03:58 PM
Central California
Central California
That's the one. Thanks for posting the pic as I haven't been able to put my eyes on one yet. Would I have the 172T flywheel now on the 318?? I beleive I have the NP420 transmission.
Re: 63 D100 Big Block Bellhousing [Re: MoParFish] #1691554
10/31/14 01:27 PM
10/31/14 01:27 PM
dogdays Offline
dogdays  Offline
My '64Dog had the 172 tooth flywheel and the NP420, it is only synchronized in Third and Fourth.
R.
Re: 63 D100 Big Block Bellhousing [Re: MoParFish] #1691555
10/31/14 05:08 PM
10/31/14 05:08 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Industrial BB's used an extended crank hub on the rear, it was also an 8 bolt pattern but with a different spacing than a HEMI.
Re: 63 D100 Big Block Bellhousing [Re: WO23Coronet] #1691556
11/06/14 02:51 PM
11/06/14 02:51 PM
dogdays Offline
dogdays  Offline
OP, I have my '64 D100 318 4-speed truck apart right now if you want pictures. But you gotta respond fast, I'm supposed too be driving it this weekend!
R.
Re: 63 D100 Big Block Bellhousing [Re: dogdays] #1691557
11/06/14 04:23 PM
11/06/14 04:23 PM
Central California
Central California
R.
Pics would be great! I sent you a PM with my email or post pics here on forum whichever is easier for you. Thanks!! Mike
