Re: BBM Pistons for B1 heads work with conventional heads?
[Re: johnnyd]
#1691186
10/27/14 01:01 PM
10/27/14 01:01 PM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
i would say no, unless you have a very low lift <.600 or the piston was way down in the hole.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#1691187
10/27/14 03:13 PM
10/27/14 03:13 PM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
Joe
they are in two different locations. It can be cut though.
[Re: johnnyd]
#1691190
11/10/14 07:07 PM
11/10/14 07:07 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have heard of this before. If the piston is B1 based, then there will be enough room for the rings and the valve reliefs, as the B1 is a tighter situation. If the piston is based on a standard wedge head, there might be problems. I wouldn't buy anything though without having an engine builder measuring it for the cam and heads you want to run.
[Re: johnnyd]
#1691191
11/10/14 08:19 PM
11/10/14 08:19 PM
Posts: 316 Utah
dragnduster
Utah
I emailed Indy and never heard back.
I also emailed Koffel and heard back from them. They said that the B1 piston will work with a conventional head- just need to account for the compression ratio being lower from the increased valve reliefs in the B1 piston over a conventional headed piston relief.
Thanks for the update, I am going to put my Victor heads on a B-1 based 512" lowdeck short block and I was hoping not to have to change pistons. ![](/ubbthreads/images/graemlins/thumbs.gif) I will definitely check p/v clearance to make sure though.
