Re: Taller 17" tires for classic Mopars? [Re: beecrazy69] #1690812
10/27/14 02:50 AM
10/27/14 02:50 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's all perception. Feets and Goody's rims look good, imo. 17" ralleys something is off in how they look.
But that is my opinion.
I got 17's on my DD and 15's on my 65 Cuda, when you consider that the Cuda came with 13's it's a big step up. I can't imagine how it'd look with 17's.
Don't be the exception.
Re: Taller 17" tires for classic Mopars? [Re: Supercuda] #1690813
10/27/14 03:25 AM
10/27/14 03:25 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I will agree on the plus sized rally wheels. They look like poo. The proportions are all jacked up. The center cap is too small for the outer diameter and the wheel bolt pattern is dwarfed in the middle of it.
When you get used to seeing a wheel in certain proportions it looks out of sorts when only part of it gets stretched.
- Stu Harmon
Re: Taller 17" tires for classic Mopars? [Re: feets] #1690814
10/27/14 11:41 AM
10/27/14 11:41 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
On e-bodies and 71 and up b-bodies, 17s look right at home. I ran 20s on the back of my challenger and I admit they looked too big but they were actually cheaper than going 15, 17 or 18. The problem with 15s is there are only so many options, even 17s don't have as many as 18 or 20s.
Google tire size chart and you can see the tire sizes and compare to known 15" or other combos that are known to work.... then pick the size you want.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Taller 17" tires for classic Mopars? [Re: Silver70] #1690815
10/27/14 12:37 PM
10/27/14 12:37 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
the 70 Satellite wheel well openings are huge.
My rears are 17" tires are 275-60-17 and measure at 29.98. Sadly these are no longer available, so no more burnouts for me.
Increasing the wheel diameter is fine when increasing the sidewall to match.
Ultimately its your car. Screw it if the rest don't like it.
...FAFO...
Re: Taller 17" tires for classic Mopars? [Re: skicker] #1690816
10/27/14 02:38 PM
10/27/14 02:38 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
275/40 17s all around, just put on a couple weeks ago. Thinking I may want to lower it a little. I wish someone made a 275/45.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Taller 17" tires for classic Mopars? [Re: feets] #1690817
10/27/14 03:36 PM
10/27/14 03:36 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I think they look awful.
Ok.
Some people gotta stick with original.
Others, like us, would rather have a far more capable (and safer) car.
Too many loonies on the road in cars that far outperform the old stuff from the 60s, especially in braking.
Admittedly, I prefer the stock look so nothing bigger than 15's for me. OTOH, some with larger diameter rims don't look bad and I always thought the hotrod looked good.
I would, however, like to address the alleged safety issue; though it is true that most modern cars outperform our old cars as it relates to handling and braking, it isn't as though they are inherently unsafe; my car with radial tires and factory disc brakes does just fine...you need to keep in mind that there are many vehicles on the road today that can't come close to even 1970 passenger car braking and handling....tractor trailers, pickups with campers and travel trailers, motorhomes, etc. etc. My Superbee outhandles and outbrakes my Ram diesel with my camper on board....and I have no safety concerns driving either one....you just have to THINK about what you're driving. Otherwise logic would dictate that we are all insane for driving anything other than a new Corvette (or similar).
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Taller 17" tires for classic Mopars? [Re: Slant6pak] #1690818
10/27/14 04:36 PM
10/27/14 04:36 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
275-60-15 rear(28 inch), 235-60-15 front. Excellent stance, good ride, so so handling and braking.
'O' ring tires on oversize rims, DUBS is the man, IMHO.
Re: Taller 17" tires for classic Mopars? [Re: Butterscotch71] #1690819
10/27/14 05:34 PM
10/27/14 05:34 PM
AndyF Offline
AndyF  Offline
Yeah, the 275/40-17 is a little too short. Even a 275/45 is short. You really need to stay larger than 27 inches to fill up the wheelwells. A car like that has big wheelwells so you can go even larger than 27 inches of diameter. You can probably fit a 275/60-17 in the rear, not sure about the front. Perhaps a 275/50-17 will fit up there?
Re: Taller 17" tires for classic Mopars? [Re: AndyF] #1690820
10/27/14 07:18 PM
10/27/14 07:18 PM
france
jose jones Offline
jose jones  Offline
france
Don't listen to these guys that a 15 inch tire and wheel is the only way ,17 inch wheels are awesome on these old cars The quality of a 17 inch Nitto tire is far superior to a 15 inch BFG radial T/A. several years ago on the way to a Mopar show in November I blew a 235-60-15 BFG Radial T/A about tore the front fender off the car, NO ONE in the USA had a new one, BFG was not scheduled to make another batch until the following February
No more 15 inch tires for me you are just screwed if you mess one up out on the highway
Re: Taller 17" tires for classic Mopars? [Re: DPelletier] #1690821
10/28/14 02:55 AM
10/28/14 02:55 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I don't see it as an alleged safety issue. Instead, I see it as giving me a fighting chance to either stop or get out of the way.
It's not possible to win every battle on the street but I'll take any advantage I can get.
- Stu Harmon
Re: Taller 17" tires for classic Mopars? [Re: AndyF] #1690822
10/28/14 03:25 AM
10/28/14 03:25 AM
Las Vegas, NV
Tom_440 Online work
Tom_440  Online Work
Las Vegas, NV
I agree. But I wanted to keep all tires the same size so went with 275-40-17 for autocross. I kept the Cragers and BFG's on the shelf, but really like driving with the Nittos far better!
Re: Taller 17" tires for classic Mopars? [Re: Tom_440] #1690823
10/28/14 12:07 PM
10/28/14 12:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A good set of tires makes an amazing difference.
- Stu Harmon
Re: Taller 17" tires for classic Mopars? [Re: feets] #1690824
10/28/14 01:09 PM
10/28/14 01:09 PM
DPelletier Offline
DPelletier  Offline
Peterbuilt has your ride then!
Seriously, if you seriously want to do everything you can to mitigate risks then you should drive a new car. Stability control, traction control, airbags, ABS. etc. etc.
OTOH what do I know about risk mitigation, I ride motorcycles.
Re: Taller 17" tires for classic Mopars? [Re: Tom_440] #1690825
10/28/14 02:06 PM
10/28/14 02:06 PM
AndyF Offline
AndyF  Offline
It also depends on the car. We ran 275/40-17 tires on all four corners on Tim's road race Valiant. Those tires really fill up the wheelwells on an A body but they might look small on a late B-body.
Re: Taller 17" tires for classic Mopars? [Re: DPelletier] #1690826
10/29/14 09:54 AM
10/29/14 09:54 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
There's no "U" in Peterbilt. Sorry, I had to fix that one for personal reasons.
Re: Taller 17" tires for classic Mopars? [Re: GoodysGotaCuda] #1690827
10/29/14 11:11 AM
10/29/14 11:11 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
There are alot of nice rides & wheel & tire combo's posted here. I am a 15" tire & wheel guy myself on all of my cars. Although, I have never been able to afford anything larger to ever try out on my cars anyway. They have all always rode, drove & stopped just fine for the last 40 years. My 2012 Challenger however does have 20" wheels & tires on it & I think they also look to big on this car too but it is growing on me.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Taller 17" tires for classic Mopars? [Re: 68LAR] #1690828
10/29/14 11:26 AM
10/29/14 11:26 AM
midwest - USA
69/70 Plymies Offline
midwest - USA
MY opinion..... I don't like that type of wheel/tire combo on ANY old muscle car. To me, it just don't look right. 15 inch wheel is max in my book.
Just my opinion and
A BIG 10-4 on that opinion. I agree 110%!
Re: Taller 17" tires for classic Mopars? [Re: DPelletier] #1690829
10/29/14 12:56 PM
10/29/14 12:56 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I drive a 2014 Chrysler 200 daily. It performed fairly well in crash testing.
The Imperial gets driven for pleasure and you never know what will happen on the streets.
- Stu Harmon
Re: Taller 17" tires for classic Mopars? [Re: 69/70 Plymies] #1690830
10/30/14 02:48 AM
10/30/14 02:48 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Just my opinion and
I'm of that "old" school of thought as well. I personally prefer the 15" wheel look on this era of muscle cars. Granted, I did briefly consider going 17", but in the end, I decided to stay 15". Here are some photos of my new American Racing AR500 (aka VN500) wheels.
