Re: 4 link setup
[Re: Quicktree]
#1690738
10/26/14 01:47 PM
10/26/14 01:47 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
So much more info is needed. How did the car react? Did it blow the tires off at the hit? Did it drive out and then spin? Did you try altering launch rpm? Stick or auto? ETC...
Re: 4 link setup
[Re: Quicktree]
#1690741
10/26/14 02:24 PM
10/26/14 02:24 PM
Posts: 2,872 CheddarHead till October
weedlayer
It's not blowing them off or unloading. I do think it is developing too much wheel speed. So far, been twice, just me, so no video. I do know, mph is up about 3, et overall is down, but 60 is not improved or even a little worse from before the changes. There are more adjustments that still keep me within the program recommended area. Just don't know how radical to get with their settings. I want to keep the front wheels at least somewhat close to the ground. ![](/ubbthreads/images/graemlins/laugh2.gif) I have dropped the tire pressure from 15 to 12, and that has changed nothing. Tires are 13.5 x 31 with tubes. ![](/ubbthreads/images/graemlins/drive.gif)
Re: 4 link setup
[Re: FastmOp]
#1690746
10/26/14 02:42 PM
10/26/14 02:42 PM
Quicktree
Bottom bar should be slightly lower in the front. Not running uphill like yours.
good catch, level or slight down is where mine end up.
Re: 4 link setup
[Re: Quicktree]
#1690747
10/26/14 04:38 PM
10/26/14 04:38 PM
Posts: 11,747 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
130MPH. 3200#. 53% on the nose. 2.45 low?
Looking at the diagrams, looks like the 4 link chassis brackets are too high in the car. Don't know if the bars can be put where they need to be. Looks like the first configuration is closest, but there's no room for improvement. Top bar should be as far from the housing as possible and running maybe 15 degrees down (at least). Bottom bar also as far from the housing as possible to start. Maybe downhill a degree. If it still doesn't hit the tire, try making it level or up in the front slightly to help apply the tire. Bottom bar rarely needs to go beyond a degree or 2 up or down. Start the rear shock dead loose on extension. Keep the compression in the middle. If it's not a double adjustable, just get the extension as loose as you can. Instant center should end up 40-42" out. Start there.
Yes that's short. I've run them shorter with that power level. Converter design, gear ratios, stick vs. auto, stroke, and a hundred other things influence it. Lack of horsepower/weight distribution = you have to get aggressive with it.
Re: 4 link setup
[Re: CMcAllister]
#1690748
10/26/14 10:23 PM
10/26/14 10:23 PM
weedlayer
ok, starting to make sense. I can lower the bottom shock mount a hole or 2 and lower the body, that would drop the front bar holes giving more down or straight angle options for the bottom bar. Sits kinda high in the rear anyhow. Shocks are only 3 way adjustable. Quote:
Our Rear Drag Shocks are also adjustable in three ratios: 70/30, 60/40 and 50/50. These ratios also represent the percentage of force required to compress and extend the shock unit. Only this time, the first number is compression and the second extension.
excuse my ignorance, but which is loosest on extension?
also, now that I know what weight is actual, what coil should I have on the rear for 1520#?
Re: 4 link setup
[Re: weedlayer]
#1690750
10/27/14 01:28 AM
10/27/14 01:28 AM
Posts: 740 WA
JD Dart
WA
If it was me I would put it in the top axle bracket top hole because you don't have a ton HP you need the mechanical advantage. 1. Top Axle bracket top hole. 2. Bottom Axle bracket bottom hole To get more spread on the bars this may not work for you again you need more HP mostly more spread is to calm done tire shake. 3. Top chassis bracket 3 hole down from the top. 4. Bottom chassis bracket bottom hole. Try for IC 47'-53' and 7'-4' up But I don't ![](/ubbthreads/images/graemlins/shruggy.gif)
best so far 8.53 @ 158.59 MPH 60'1.240
Re: 4 link setup
[Re: 68roadrunner]
#1690752
10/27/14 04:06 PM
10/27/14 04:06 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Jess's advice is pretty good. Shocks need to be good, spring rates, well opinions vary. Me I like just enough to hold the car up. Get some scales or get it scaled as well.
Re: 4 link setup
[Re: Al_Alguire]
#1690753
10/27/14 10:41 PM
10/27/14 10:41 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
130# springs is what I would start with. You'll have to compress them them to get the shock to the right installed length. That will store some energy and help get the tire applied. Without a decent double adjustable shock, you may as well have put ladder bars on it. Proper installed length of the shock has to be maintained after moving ride heights and shock mounts. Lowering the car some would help the 4 link geometry. Ideally, with the rear at ride height, the bottom hole in the chassis bracket should be the same height from the ground or slightly lower than the bottom hole of the axle bracket.
