72 Duster Door won't open
#1690474
10/25/14 06:58 PM
10/25/14 06:58 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Door panel is off. Button and mechanism looks to all be working. Is there some type of fail safe or part of the mechanism that can be moved manually to get the door open? Also what could be broke to keep the door from opening. thx matt
[img] [/img]
Re: 72 Duster Door won't open
[Re: clonestocker]
#1690475
10/25/14 07:01 PM
10/25/14 07:01 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
body twisted? broken striker?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: clonestocker]
#1690481
10/25/14 10:13 PM
10/25/14 10:13 PM
Posts: 2,763 Myrtle Beach, SC formerly the ...
340wedge
True story. I put new door panels on my car and could not get either door open, I had my father in law come over who is a mechanic as I tried everything and was dumb founded. He said try the simplest things first..He put some grease on the internal door mechanisms, 12 years later the doors still work fine, who would figure two doors needing it at the same time, I still cannot believe it and I was there.
1971 Sassy Grass Green Duster 340 2006 Charger Daytona GoMango
[Re: clonestocker]
#1690482
10/26/14 01:13 AM
10/26/14 01:13 AM
Posts: 137 midwest - USA
69/70 Plymies
midwest - USA
Cars fine. Broken striker? The door didn't want to stay closed at all then it shut tight but won't budge. Panels off looking @ latch looks ok. The pin was stable. in the door. any ideas?
Had the same problem with the door not wanting to stay closed on a '70 B-body. My son freaked out and swore it was "shot" and he left the scene. I opened the door and examined the latch mechanism on the door (that contacts the striker on the chassis) and applied silicone spray to the small shaft with spring. The white plastic piece rides on this small shaft. The door stays shut when closed, now. Not sure if this relates to your situation, but may be a good idea once you get the door open! Can you spray the latch area at all with the door stuck shut?????
[Re: clonestocker]
#1690485
10/26/14 02:49 AM
10/26/14 02:49 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Okay....So this aint one of the EASY fixes! ![](/ubbthreads/images/graemlins/hammer.gif) I'll guess that you have already flooded the latch with a WD40 or PB blaster type lubricant. A long drift and a light tapping with a hammer may pop it loose. It may not. report back, we WILL "figger" it out.
