1974 charger fuel gauge not working?
#1690363
10/25/14 04:26 PM
10/25/14 04:26 PM
Posts: 261 Albuquerque, new mexico
moparvinson
trying to get my sons fuel gauge to work, have tried 2 different sending units and have moved the float full swing and the gauge still reads below empty? I have checked with a voltage meter and it reads .25 volts, is that normal or should I be getting 12v? could it be a stuck gauge? thanks for any help, p.s. it is a standard gauge cluster.
Re: 1974 charger fuel gauge not working?
[Re: stumpy]
#1690365
10/25/14 05:45 PM
10/25/14 05:45 PM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
If you check the sender wire with a voltmeter you should be getting a pulsing 5v.
Does your temp gauge work?
If not, I suspect the Voltage Reg. on the back of the cluster.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: moparvinson]
#1690368
10/26/14 04:44 PM
10/26/14 04:44 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
well, I think you got the fail. Need to consider if just one gauge doesn't work, never will be the limiter since limter works to feed all meters less the ammeter.
The deal is if your rallye cluster got the big opening gas and oil meters, is one piece gauge, so make sure your oil gauge works too on the donor car.
