383 bore notching #1690272
10/25/14 02:19 AM
10/25/14 02:19 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
When did you do it? What valve size and lift is he generally accepted threshold?
Current plan is 2.14/1.81 valves and .500" lift (figured with a 1.5 rocker ) and about 300 duration. ( I'd have to pull the card)
Re: 383 bore notching [Re: NTOLERANCE] #1690273
10/25/14 02:22 AM
10/25/14 02:22 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
Im 2.14 1.81 with a 4.280 bore , 590 lift and there is lots of room.
Hutch
Re: 383 bore notching [Re: NTOLERANCE] #1690274
10/25/14 10:27 AM
10/25/14 10:27 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
When do you need to do it, or when should you do it?
I always chamfer the top of the block if it protrudes into the combustion chamber around the valves.
Re: 383 bore notching [Re: BSB67] #1690275
10/25/14 11:11 AM
10/25/14 11:11 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
me too! been doing it since early '70's. 426 wedge nascar blocks were factory notched for intake and exhaust.
Re: 383 bore notching [Re: NTOLERANCE] #1690276
10/25/14 04:22 PM
10/25/14 04:22 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
There's a much easier solution, unless it's a resto type build. (Use a 400 block)
Re: 383 bore notching [Re: 451Cuda] #1690277
10/25/14 06:45 PM
10/25/14 06:45 PM
Madison Wi
Madison Wi
383 short block that needs no machining or a 400 that needs everything - Ive put the 400 up for sale. If I were to use it it would be a 451 stroker - since I have those parts and the machining wouldnt be alot different than a stock 400.
Likely never get to that. Ive had it ten years. I have two really nice low use 383s - no ridge and clean cranks.
