Re: My W9 Build
[Re: MattW]
#1690099
10/24/14 10:00 PM
10/24/14 10:00 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
That should really make some steam. It might like a little more duration , but I guess that depends on your end use too. Mine is a 405 ( 4.125 X 3.79 ) with a little more compression and a different cam....268 @ .050 and .680 ish lift on a 104 center and in at 102. The heads flow less.......348 @ .700 and I think 248 on the exhaust. I ran out of time and money so it never went on the pump , but it has more than fair street manners and really pulls once it hooks. It ran hotter than I expected ( over 210 on hot days. ) , but I just went with the HHR fan / shroud and that fixed that issue. Cold starting with E-85 takes a while , but if the air is over 65 or so it isn't a problem. My plans for hitting a test day before the season was over got waylaid by a couple family weddings , but I can't wait for next spring to bury the speculation regarding what it will do. Me thinks you're gonna really enjoy that one.
Re: My W9 Build
[Re: MattW]
#1690101
10/24/14 10:13 PM
10/24/14 10:13 PM
Posts: 3,396 Pa
Hot 340
Pa
Some people were asking for some info.
436ci 4.04×4.25 Block: Mopar R3 Compression Ratio: 11.43:1 Crankshaft: BPE Connecting Rods: Scat 6.2-inch I-beam Pistons and Rings: Total Seal .043/.043/3mm rings Camshaft: Comp 250/252 degrees at .050, .735/.685 lift, 108 degrees LSA Cylinder Heads: Brett Miller small CNC Mopar W9 363cfm max intake flow, 255cfm exhaust flow. Intake Manifold: Mopar 420 Matt
Do you think you'll overpower that rod with this combo?
That crank has a 2.00 rod journal right? Didnt know scat made a 6.200 I beam with a 2.00 big end.
Re: My W9 Build
[Re: J_BODY]
#1690102
10/25/14 12:06 AM
10/25/14 12:06 AM
tubtar
St. Paul , Mn.
timing chain (do you have a cover?)? or weber belt drive?
keeping the stock front end?
got a header builder handy?
2 speed trans? ....or torqueflight torture (I chose the latter so far...)
running a 4500 carb? or sticking with a 4150? My 598 intake and spacer for 4500 sits to high....going to have the intake modded to a 4500 flange eventually.
All pertinent questions. Weber belt and front drive distributor here....mostly for show and tell. And an AlterKtion or I'd never even try making headers for it. I went under sized with the carb.........a QuickFuel 850 done for E-85. One of a couple compromises I made to keep some manners. I made my own headers....1 7/8" X 35 " primaries into a 3 1/2" collector. I bought a set of Flowmaster 4 into 2 into 1 - 3" collectors , added tubes for the evac and had them coated only to decide that enhancing low end torque was not going to be a priority. And a low 1st gear 904 with a 3.91 rear cog that feels O.K. , but it runs out of first in a big hurry. 3200 rpm @ 55 mph .......not horrible , but I don't see any long trips in my future.
Re: My W9 Build
[Re: tubtar]
#1690106
10/25/14 09:48 AM
10/25/14 09:48 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
What block are you using? Why such a small bore?
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: My W9 Build
[Re: J_BODY]
#1690109
10/25/14 11:16 AM
10/25/14 11:16 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Stock
Yes
No
727.
My carb will be 1025 race demon.
Re: My W9 Build
[Re: Hot 340]
#1690110
10/25/14 11:21 AM
10/25/14 11:21 AM
MattW
Ontario Canada
Don't know about the rods but everything I've read is stroke and speed. This thing is all done at 6500 rpm.
They do unless I was given wrong info. Matt
Re: My W9 Build
[Re: MattW]
#1690111
10/25/14 11:32 AM
10/25/14 11:32 AM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
The little enginemaster's 318 I bought has a 6.200 Scat I beam Chevy rod in it.
Re: My W9 Build
[Re: B3422W5]
#1690114
10/25/14 01:45 PM
10/25/14 01:45 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Seems like a waste to run such a tiny cam and bore on a motor/ heads with a lot of potential.
sometimes "potential" is pretty hard on stuff....
Re: My W9 Build
[Re: Thumperdart]
#1690116
10/25/14 02:30 PM
10/25/14 02:30 PM
MattW
Ontario Canada
My first thaught.............hugh lift but baby duration........
Keep in mind that this venture was a last minute deal so to speak. The stuff that's in this engine is stuff that was already purchased. I was not built specifically for engine masters. It was more of let's see what all this can do. I had a couple of limiting factors one being a hydraulic roller and compression. I want to be able to drive this thing around town if I ever get my junk together. Matt
