Page 2 of 4 1 2 3 4
Re: My W9 Build [Re: J_BODY] #1690117
10/25/14 02:39 PM
10/25/14 02:39 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Seems like a waste to run such a tiny cam and bore on a motor/ heads with a lot of potential.
sometimes "potential" is pretty hard on stuff....
Would be a sweet cam for a turbo motor
Re: My W9 Build [Re: MattW] #1690118
10/25/14 02:48 PM
10/25/14 02:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My first thaught.............hugh lift but baby duration........
Keep in mind that this venture was a last minute deal so to speak.
The stuff that's in this engine is stuff that was already purchased.
I was not built specifically for engine masters.
It was more of let's see what all this can do.
I had a couple of limiting factors one being a hydraulic roller and compression.
I want to be able to drive this thing around town if I ever get my junk together.
Matt
Not baggin and using what you`ve got it is what it is..............
Re: My W9 Build [Re: TRENDZ] #1690119
10/25/14 02:52 PM
10/25/14 02:52 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Now there's an idea!
Matt
Re: My W9 Build [Re: Thumperdart] #1690120
10/25/14 03:02 PM
10/25/14 03:02 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Matt
All good
Not a keyboard whiner. Truth is it will probably sit for awhile before anything happens.
R3 is good but not worth my time for high compression big mechanical with the sloppy 59 degree lifter angle.
I would love to have a 48 degree siamese block.
But I've moving towards the new G3. Matt
Re: My W9 Build [Re: B3422W5] #1690121
10/25/14 04:13 PM
10/25/14 04:13 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
The little enginemaster's 318 I bought has a 6.200 Scat I beam Chevy rod in it.
With a 2.0 journal?
Re: My W9 Build [Re: Hot 340] #1690122
10/25/14 05:05 PM
10/25/14 05:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
With a 2.0 journal? [/quote
Said in the enginemaster's article he just widened the throws to accept the Chevy rods. Haven't had the shortblock apart
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
Best so far, 10.32 1/4
1.41 best 60 foot
6.56 at 104.17
Re: My W9 Build [Re: B3422W5] #1690123
10/25/14 08:36 PM
10/25/14 08:36 PM
BPE Offline
BPE  Offline
I'm pretty sure scat doesn't make a small journal I beam SBC rod in 6.200" length. But, I have been wrong before.
Rod
Re: My W9 Build [Re: BPE] #1690124
10/25/14 08:47 PM
10/25/14 08:47 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Rod
I've seen them but can't find tthem . lol
It's an I beam and it's 6.20 and your crank is 2.00 rod sooooo
Re: My W9 Build [Re: MattW] #1690125
10/25/14 08:59 PM
10/25/14 08:59 PM
BPE Offline
BPE  Offline
I'm not saying they aren't out there, I'm just saying I've never seen them. When you know for sure, let me know. Also, do you have a part number for the T and D rockers for the 59 degree W9 heads?
Rod
Re: My W9 Build [Re: BPE] #1690126
10/25/14 09:14 PM
10/25/14 09:14 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Not thinking that at all.
I believe the part # is Sca2 ICR6200-7/16A
As for the rockers I believe I have the raise port version because they have the most offset. 8097.
Matt
Re: My W9 Build [Re: MattW] #1690127
10/25/14 09:17 PM
10/25/14 09:17 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Yeah that's the most offset. .750 offset IIRC
Re: My W9 Build [Re: SpareParts] #1690128
10/25/14 09:34 PM
10/25/14 09:34 PM
The Great White North
RAMM Offline
RAMM  Offline
The offset is .770" and it needs every bit of it. Scat DOES offer the rod in a 2.00" journal, its right on their site in the Chevy section. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: My W9 Build [Re: RAMM] #1690129
10/25/14 09:39 PM
10/25/14 09:39 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Not 6.200 long.
T&D makes a .775 for the rp head. Its what I'd use on a 59.
Re: My W9 Build [Re: Hot 340] #1690130
10/25/14 09:56 PM
10/25/14 09:56 PM
BPE Offline
BPE  Offline
There is nothing listed on Scat's website for an I beam in 6.200" with a small journal. You might be thinking an H beam (that's listed). Thanks for the info on the T and D part number.
Rod
Re: My W9 Build [Re: BPE] #1690131
10/26/14 10:19 AM
10/26/14 10:19 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
how much power is he leaving on the table running a small bore combo
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: My W9 Build [Re: BPE] #1690132
10/26/14 10:56 AM
10/26/14 10:56 AM
RAMM Offline
RAMM  Offline
Rod
I will supply the part # on Monday along with a phone number and contact name @ Scat Enterprises. J.Rob
Re: My W9 Build [Re: Ian] #1690133
10/26/14 11:05 AM
10/26/14 11:05 AM
RAMM Offline
RAMM  Offline
We will never know. J.Rob
Re: My W9 Build [Re: RAMM] #1690134
10/26/14 11:11 AM
10/26/14 11:11 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
what would be your minimal bore size for the w9/8 head would you run thanks
Re: My W9 Build [Re: Ian] #1690135
10/26/14 11:17 AM
10/26/14 11:17 AM
RAMM Offline
RAMM  Offline
I would let Brett Miller answer that if he sees this. I can say that a larger bore fixture on the flow bench didn't unlock much more in terms of flow rate though. J.Rob
Re: My W9 Build [Re: RAMM] #1690136
10/26/14 11:35 AM
10/26/14 11:35 AM
BPE Offline
BPE  Offline
Rod
Enterprises. J.Rob
Thanks,
I contacted them a while back checking on them and they said they didn't make them. Hopefully they are now available. A part number would be great.
Rod
Page 2 of 4 1 2 3 4
