Mopar P4876731 (MSD 7AL-2) Ignition Wiring Instructions #1690019
10/24/14 12:04 PM
10/24/14 12:04 PM
Utah, USA
1964superstock Offline OP
Utah, USA
I am in need of a wiring diagram for the terminals on the Mopar Performance P4876731 ignition box I picked up. I am assuming is is similar to the (MSD 7AL-2) wiring instructions, but a few of the terminal locations are different. I called the MSD tech line and the Mopar Performance tech line, but neither had any useful information on this box. If someone could upload a scan of instructions to identify the ignition box terminals I would appreciate it. A list of the terminal locations would also work great. Thanks!
Re: Mopar P4876731 (MSD 7AL-2) Ignition Wiring Instructions [Re: 1964superstock] #1690020
10/24/14 02:20 PM
10/24/14 02:20 PM
One of the engine dyno shops I use have that one instead of the MSD 7AL2, they wire the same I hope you can read the label in this picture of my 7AL2 if not say so and I will write it out later after hearing backThe ignition (RED)terminal is for the 12V switched lead Another pointer is that the stock type Mopar distributor with the magnetic pickup is the black wire coming out of them is the minus side( MAG -, the other color is the MAG+) of the pickup IHTHs
Re: Mopar P4876731 (MSD 7AL-2) Ignition Wiring Instructions [Re: 1964superstock] #1690021
10/24/14 03:31 PM
10/24/14 03:31 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
I hope this is what your after
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
