Front shocks for a ladder car? #1689084
10/22/14 03:24 PM
10/22/14 03:24 PM
tboomer Offline OP
tboomer  Offline OP
Thought I would bring this up again. I will be looking for a decent shock that is better than the 14+ year old CE 90/10s on the front of my 64 330 sedan. I think DVW suggested the QA-1s? My car is a ladder bar car. Thanks guys!
Re: Front shocks for a ladder car? [Re: tboomer] #1689085
10/22/14 03:56 PM
10/22/14 03:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The answer is buy the BEST shock you can afford. IMO Strange is a good value as is Afco.
Re: Front shocks for a ladder car? [Re: tboomer] #1689086
10/22/14 04:42 PM
10/22/14 04:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Is the car not hooking/ working?
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Front shocks for a ladder car? [Re: B3422W5] #1689087
10/22/14 08:06 PM
10/22/14 08:06 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I ran QA-1 singles for nearly 2 years. It now has Afco doubles. So far I've been able to pick-up .03 in 60 ft. It does seem to be more consistent. Though I ran a slew of mid 1.30 60 ft with the QA-1's. I've moved ladder bars,swapped shocks, adjusted shocks, swapped tires. All this has gained me less than .10 in 60 ft.
Doug
Re: Front shocks for a ladder car? [Re: dvw] #1689088
10/22/14 09:22 PM
10/22/14 09:22 PM
Penna
70satelliteguy Offline
Penna
I also run QA-1's. Ladderbars,3600 lbs. 1.31 60 fts.
I guess a more expensive shock may work better
Mike
Re: Front shocks for a ladder car? [Re: tboomer] #1689089
10/22/14 09:34 PM
10/22/14 09:34 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
QA1 single adjustable shocks on mine.
Only 15 passes on the car total, so not a lot of shock testing. So far the biggest improvements have come from tire pressure adjustments.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Front shocks for a ladder car? [Re: Al_Alguire] #1689090
10/22/14 11:23 PM
10/22/14 11:23 PM
I messed up and bought a set of the QA1 single adjustables for my Duster and then ended up buying a set of Koni SPA speed sensing front shocks later, way better On the rear same thing, buy the best ones you can, once I started out with Strange single adjustables coilovers on the rear with the ladder bars, I ended up buying a set of the same length and appication Strange double adjustables the second time around Some of us learn the hard way, some never learn I'm still trying to learn, thats why I read and post on here
Re: Front shocks for a ladder car? [Re: Cab_Burge] #1689091
10/23/14 12:34 AM
10/23/14 12:34 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Shocks are one of the FIRST places you SHOULD spend money, yet one of the last that most do, if at all. Spend all kinds of money on engine mods and "cool guy" suspension parts, yet run 60s tech 90/10s
Monte
Re: Front shocks for a ladder car? [Re: Monte_Smith] #1689092
10/23/14 09:22 AM
10/23/14 09:22 AM
tboomer Offline OP
tboomer  Offline OP
Thanks everyone! High dollar shocks are out of the question. Like Santuff or stuff like that. I don't know till next May if I can drive or not. Hell...I don't know if I will even keep the car!
Re: Front shocks for a ladder car? [Re: tboomer] #1689093
10/23/14 12:34 PM
10/23/14 12:34 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Ted,we use QA1 and Comp Eng shocks on most of our ladder bar cars.We set the extension as loose as we can and compression as tight as we can.Most of our ladder bar B-bodys similar to your car work well and see low 1.30 to 1.26 60 fts.On a high nine to ten second bracket car it's what works and what makes each run consistant that is important.Quick lift and weight transfer of the weight and keeping the weight planted while under power is important.A loose rebound will cause suspension dynamics which can cause et loss and occasionally steering issues on the big end and when braking.This referrs to stock suspension backhalved cars and not full chassis cars.
Re: Front shocks for a ladder car? [Re: B G Racing] #1689094
10/23/14 01:27 PM
10/23/14 01:27 PM
tboomer Offline OP
tboomer  Offline OP
Thanks Bob! I am in no big hurry but will be making a few calls.
Re: Front shocks for a ladder car? [Re: tboomer] #1689095
10/23/14 02:59 PM
10/23/14 02:59 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I bought a set of Vi=king Da shocks.Rears are in and still have to weld the new mounts up front to install. Have not been able to tune them yet. Hope to see a great improvement
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Front shocks for a ladder car? [Re: hemi-itis] #1689096
10/23/14 03:05 PM
10/23/14 03:05 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Has anyone bought their shocks direct from a custom builder so they are pre-valved for their application? I plan to get some double adjustable shocks next year and this was a route I was thinking about going with some middle of the road shocks.
Adriel Paradise
Substation Design Engineer III
Re: Front shocks for a ladder car? [Re: hemi-itis] #1689097
10/23/14 06:35 PM
10/23/14 06:35 PM
tboomer Offline OP
tboomer  Offline OP
Al...How is the quality on those shocks?
Re: Front shocks for a ladder car? [Re: tboomer] #1689098
10/25/14 12:53 AM
10/25/14 12:53 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I called Mark Menscer and ordered Afco Double adjustable shocks and he made them for my car he is a good guy to talk to and he will help you and he sends a sheet on what to adjust them to and I got them today and I ordered them 10 days ago they look great .I can`t wait to try them out next week
Re: Front shocks for a ladder car? [Re: tboomer] #1689099
10/25/14 02:12 AM
10/25/14 02:12 AM
Closest Race Track
W
WH23H6 Offline
WH23H6  Offline
W
Closest Race Track
QA 1 singles on the front... Koni Dbls on the back... 3300lbs.. 1.30 60ft consistently.... with the odd 1.28s..
While we are talking shocks... heres a question (for Bob maybe) I had issues at Norwalk getting the car to leave... never had a chance to get it out again until last weekend at testing.. Playing with the shocks (rear) last weekend I had a thought that perhaps the cold air was affecting the oil in the shock... so we loosened the extension more than ever before and found very favourable results. Has any body else noticed this in cooler temps?
Re: Front shocks for a ladder car? [Re: steeldust] #1689100
10/25/14 02:18 AM
10/25/14 02:18 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
May I ask how much they cost per shock? I have a ladder bar car that is new to us and am all ears on this thread.
Re: Front shocks for a ladder car? [Re: tboomer] #1689101
10/25/14 11:17 AM
10/25/14 11:17 AM
gregsdart Offline
gregsdart  Offline
It all boils down to how much control you need for landing after a wheelie. I need a lot, and it started to show after the front was getting more than a foot in the air or so. A single adjustable good quality shock ought to do the job to a point, depending on a lot of things. A stock bodied drag car should be OK to 10.0 I would think. Maybe faster. Especially if the car in question runs a glide.
Re: Front shocks for a ladder car? [Re: Jeremiah] #1689102
10/25/14 08:39 PM
10/25/14 08:39 PM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
$909.00 for the front set shipped
Re: Front shocks for a ladder car? [Re: steeldust] #1689103
10/27/14 06:27 PM
10/27/14 06:27 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Thats not a terrible price given their custom built to your application. I'm looking forward to upgrading the 20yr old shock technology on our car.
Adriel Paradise
