Re: Aluminum BB Cylinder Head hierarchy
[Re: Al_Alguire]
#1689021
10/22/14 04:00 PM
10/22/14 04:00 PM
Posts: 503 Idaho
1320Dart
Idaho
I think they are pretty much obsolete these days. My understanding was they came about due to the lack of Hemi blocks back in the day. That is simply not the case these days. But contact Stage V and ask them. The Hansens are great folks, we used their stuff when we had a Hemi in the Cuda.
They still make them?!
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
[Re: 1320Dart]
#1689025
10/22/14 10:12 PM
10/22/14 10:12 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Looks like they do..
http://www.stagev.com/
http://www.stagev.com/pages/hcheads.html
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Monte_Smith]
#1689026
10/22/14 10:19 PM
10/22/14 10:19 PM
Chris'sBarracuda
Arizona
My list would be Predator....B-1 TS....B-1 PSO.......B1-MC.......B-1.......600-13......572-13......440-1 and then anything else. Might be some debate on the original B-1 vs the 600-13. Also a stretch to call a 440-1 a "race" head as it is common on street cars. I myself would pretty much consider anything less than a 440-1 a street head or street/strip head at best. Just depends on your performance goals and intended use. Just because you have an Edelbrock head on your "race" car, doesn't mean it was designed to be a "race" head.
Likely the LEAST user friendly head of the group is the B-1 TS, as there just are not commonly available parts to make it work correctly. Needs a custom intake and really needs the lifters moved in the block to be optomized
Monte
What about the B1 T/S 4.84 heads.. I remember you saying you have a set stashed away, and since the Predators are only 4.80 I would think that puts the B1 T/S on top.. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Chris'sBarracuda]
#1689027
10/23/14 04:18 AM
10/23/14 04:18 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
The 600-13 is also a 4.84 BS piece, don't necessarily mean they make any power I did not include the TS as it is a way out there exotic piece. IMO if you are gonna go that way then go 99 Hemi...
[Re: Monte_Smith]
#1689028
10/23/14 06:07 AM
10/23/14 06:07 AM
Posts: 345 Nebraska
451Cuda
Nebraska
Monte
Don't forget FBS heads, probably just above B1 originals.
[Re: 451Cuda]
#1689029
10/23/14 06:14 AM
10/23/14 06:14 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I bought a set of FBS's recently, haven't arrived yet though. Once they do, I'll have them flowed. Will use them in our 478 turbo engine.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#1689030
10/23/14 06:25 AM
10/23/14 06:25 AM
Posts: 345 Nebraska
451Cuda
Nebraska
Have them pressure tested before you run them.
[Re: 451Cuda]
#1689031
10/23/14 11:21 AM
10/23/14 11:21 AM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
So where do Bulldogs fit in that list, I know they're not available and not many out there but that's what I'm stuck with for the moment.
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Sledge_57]
#1689032
10/23/14 11:27 AM
10/23/14 11:27 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
probably right around with the Mopar StageVI head.... undesirable and near the bottom ![](/ubbthreads/images/graemlins/biggrin.gif)
#1689037
10/23/14 03:41 PM
10/23/14 03:41 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte
Chris..
I do have a set of 4.840 TS heads with the "Wayne County" head bolt pattern. They are currently at Buck Racing Engines getting some work done on them. They SHOULD be better than a Predator because of bore size alone, but I really didn't include them because of rarity and most don't even know they exist.
Monte
[Re: Digger73]
#1689040
10/23/14 04:15 PM
10/23/14 04:15 PM
Posts: 24 ms
digbyden
ms
At the risk of sounding naive. What is the pecking order of the available BB aluminum cylinder heads? Starting with the best and working down to the worst. I have been just a bit confused by all of the offerings now. Thanks, Mike (Digger73)
My 610 Predator makes 1210hp and is only 14:1…..one off set with cast tunnel ram….heads flowed 535/403…turning out to be a pretty good engine to spray
