BIZARRE Problem With A 2003 Cummins Ram. #1688564
10/21/14 02:55 PM
10/21/14 02:55 PM
Charlotte, NC
Orange_Crush Offline OP
Belieber!
Belieber!
Charlotte, NC
My older brother lives in Costa Rica. His FIL owns a 2003 2500 Cummins Ram that he uses as a work truck. This truck has been ridden hard and probably has 150-200,000 miles on it. He has (according to him) recently developed an issue.
He says that he can fill the crankcase with oil, drive 10 miles, and the crankcase will be empty. In addition, there is diesel getting into the oil. If he pulls the oil fill cap off the valve cover and puts his hand over the hole with the engine running, his hand will be wet with diesel and the dipstick has diesel on it.
It sounds to me like (this being Costa Rica) the diesel tank at the gas station may have had gasoline in it, he ran it, and totally destroyed his pistons and valves causing uncontrolled oil burning which is sucking the diesel into the crankcase through the head.
Any thoughts?
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688565
10/21/14 03:03 PM
10/21/14 03:03 PM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
I should add that the truck has no visible oil leaks.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688566
10/21/14 03:47 PM
10/21/14 03:47 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I doubt he ran gasoline in it because the truck won't run on gasoline. Sounds wore out of it's using oil like that to me.
Then I don't believe that all the oil is gone at 10 miles.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Challenger 1] #1688567
10/21/14 04:00 PM
10/21/14 04:00 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
If there is fuel in the oil, I'd be looking for a bad injector(s).
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688568
10/21/14 04:07 PM
10/21/14 04:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
12 or more qts of oil in 10 miles with no leaks ? and that thing would be smoking like a freight train
and if the rings were in fact that blown out , I would be suprised it ran at all
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: gtx6970] #1688569
10/21/14 04:15 PM
10/21/14 04:15 PM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
I have a feeling that there is some exaggeration there...but he says it's definitely losing lots of oil.
One more thing, there is a fair amount of positive pressure in the crankcase. He can feel it blowing air out of the oil fill.
I'm wondering if it isn't a combination of bad rings and a stuck injector.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688570
10/21/14 04:19 PM
10/21/14 04:19 PM
an8sec70cuda Offline
Or a piston that's melted.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688571
10/21/14 04:20 PM
10/21/14 04:20 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Any thoughts?
If they can't see where a trail of 4 gallons of oil in 10 minutes is coming out of that thing, then they shouldn't be behind the wheel.
At any rate it sounds like a wiped cylinder.
Mo' Farts
Moderated by "tbagger".
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688572
10/21/14 04:57 PM
10/21/14 04:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A faulty turbo seal would explain the oil consumption but not the diesel in the oil.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: John_Kunkel] #1688573
10/21/14 05:40 PM
10/21/14 05:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: JohnRR] #1688574
10/21/14 07:35 PM
10/21/14 07:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wouldn't that cause a runaway?
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: gtx6970] #1688575
10/21/14 08:48 PM
10/21/14 08:48 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Sure kind of throws a wrench in my theory. I've got 232K on mine, oil gets changed every 8K or so. Being that it is 12+ qts I have never pulled the dipstick to check it. It doesn't smoke and it doesn't leak so I figured it would never be low. May have to rethink that one after reading this...
...FAFO...
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688576
10/21/14 10:51 PM
10/21/14 10:51 PM
Cincinnati, Ohio
Cincinnati, Ohio
He might want to check his fuel tank for motor oil, it could get pumped in there if the injectors are fired with oil pressure and a o ring goes bad.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Challenger 1] #1688577
10/22/14 01:42 PM
10/22/14 01:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The 5.9 does not use oil fired injectors.
- Stu Harmon
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688578
10/23/14 12:17 AM
10/23/14 12:17 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Pressure in the crankcase like that says a ring or piston gone way south. I remember the 2.2 tubo cars would blow the turbo seal and use oil like crazy but they would also smoke out the shop when you pulled it in the shop. Ron
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Challenger 1] #1688579
10/23/14 06:41 AM
10/23/14 06:41 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Actually they will run on gasoline but really really badly.
On rare occasions when they had a new operator at fuel fill on the assembly line they would put in 8 gallons of gasoline in a diesel truck and it would get started on it at the Huntsville test (electrical test).
They rattled really loud but ran.
They shut them off fairly quickly, 30 seconds to a minute run time.
They were then were pushed off the end of the line to repair.
The fuel tank was drained, then replaced and then they filled with diesel fuel and were restarted and the Huntsville test was run.
The engineers said the short run on gasoline didn't hurt them.
Eventually they set up the fuel fill system to eliminate the chance of that happening by having to scan the truck being fuel filled.
It wouldn't allow you to pump the wrong fuel into a truck after it was scanned.
It would shut down the line if you did try which required a restart by the section line supervisor.
If it was run on 87 octane gasoline for any real length of time it would be really bad.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: Orange_Crush] #1688580
10/23/14 10:15 AM
10/23/14 10:15 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
These motors are real bad about an injector going bad and putting so much fuel into the cly that it will burn a hole in the piston or melt the rings. Sounds like to me, that is the problem.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: fastmark] #1688581
10/23/14 04:40 PM
10/23/14 04:40 PM
Missouri U.S.A.
Missouri U.S.A.
The 325 hp engines are WAY more likely to burn a piston than the earlier 305 hp engines. Not saying it hasn't but it is not as common for sure. The piston has a lot more "meat" around the bowl area on a 305 hp. Usually if it has burned a piston it will pulse the blowby out of the oil cap with the engine running and have a miss. You will also hear uneven cranking of the engine when trying to start the truck. The source of the fuel leak still needs to be addressed first.If you are the adventurous type, You can remove the valvecover with the engine idling to look for a fuel injector leaking into the crankcase. If no fuel leak is found initially, you may have to ramp up the fuel pressure to find the leak. This can be done by disconnecting the Fuel control actuator plug on the high pressure pump. Unplug the FCA with the engine off. By doing this the fuel pressure will be at max operating levels and the leak will be very easy to spot. Look for it to steam or fog fuel around the bad injector. Before restarting the engine with the FCA unplugged, Be sure to stand back away from the engine as it can be messy and dangerous. Have someone in the truck that can shut the engine off quickly if needed. Disclaimer: BE VERY careful if you attempt to do this. The fuel will be under extreme pressure and can hurt or even kill you if you are too close.
10.02@134
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: 71yelladustr] #1688582
10/23/14 05:50 PM
10/23/14 05:50 PM
Charlotte, NC
Belieber!
Belieber!
Charlotte, NC
Thanks for the advice, everybody.
As I said, the truck is in Costa Rica so who knows what it could be! I basically repeated all of the advice here to him and he says he'll let me know when he finds something out.
Re: BIZARRE Problem With A 2003 Cummins Ram. [Re: 71yelladustr] #1688583
10/24/14 08:23 PM
10/24/14 08:23 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
You're nuts.
This thread is outta control.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
