Need a picture of E-body axle vent bolt/brake hose moun #1688560
10/21/14 01:47 PM
10/21/14 01:47 PM
Shoreline, Washington
72roadrunnergtx Offline OP
Specifically the clocking position of the threaded vent/bolt hole in the driver’s side tube. Recently received a new Moser Dana speced out for an E-body, concerned the vent location is incorrect. Is there different brake hose mounting for the E-body vs. other models?
Looks like it's too far down the backside of the tube compared to where it was located on the modified 8 3/4" diff that came with this car.
Re: Need a picture of E-body axle vent bolt/brake hose moun [Re: 72roadrunnergtx] #1688561
10/21/14 10:54 PM
10/21/14 10:54 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
8 3/4
Re: Need a picture of E-body axle vent bolt/brake hose moun [Re: cudaized] #1688562
10/21/14 10:57 PM
10/21/14 10:57 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
2
Re: Need a picture of E-body axle vent bolt/brake hose moun [Re: cudaized] #1688563
10/21/14 11:06 PM
10/21/14 11:06 PM
BDW Offline
BDW  Offline
Yes, looks wrong. Vent should be on top not side.
You'll have to tweak the brake lines to line it up.
