Re: indy maxx or world products?
[Re: 9secondsatellite]
#1688463
10/21/14 01:04 AM
10/21/14 01:04 AM
Posts: 1,506 TN
SCATPACK 1
TN
1 what? If you are asking about Hemi blocks, I would look at HP Performance blocks in Knoxville, TN. Best quality I have seen on any of the aluminum blocks and has some nice secret modifications to it as well. Jerry
Old Geezer Racing
[Re: SCATPACK 1]
#1688464
10/21/14 01:07 AM
10/21/14 01:07 AM
And they don't have any and won't for awhile.
[Re: ]
#1688465
10/21/14 01:52 AM
10/21/14 01:52 AM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
have both here, like the indy better, alum to alum.
[Re: boatracer572]
#1688466
10/21/14 01:58 AM
10/21/14 01:58 AM
Posts: 19,399 Las Vegas
Al_Alguire
Las Vegas
And I went with World. Either way you decide to go DO NOT get it finished machine. IMO there I s no such thing. I would prefer to get one blank with no lifter holes even. But it depends on your application but certainly do not go with a "finished" machined piece.
[Re: Al_Alguire]
#1688469
10/21/14 12:44 PM
10/21/14 12:44 PM
Posts: 3,441 Mo.
supercomp
Mo.
I thought you used aHP block on your predator.
#1688470
10/21/14 01:01 PM
10/21/14 01:01 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I bought the World block. So far I am satisfied with it. We are Not near the HP levels of some here though. Mark ![](/ubbthreads/images/graemlins/thumbs.gif)
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: supercomp]
#1688471
10/21/14 02:47 PM
10/21/14 02:47 PM
Al_Alguire
Las Vegas
Nope I do have an HP block sitting in Colorado I have not even picked up yet though.
[Re: Al_Alguire]
#1688472
10/21/14 03:09 PM
10/21/14 03:09 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
thanks for the input guys. sorry, i should have specified rb block. i'm in alaska so machine work is somewhat limited. i could have whoever i get the block from also provide the pistons so they can do the finish on the bores and the lifter boss.if i wanted to go this route and use the indy block, who would be a good choice for this?
[Re: 71birdJ68]
#1688475
10/21/14 06:36 PM
10/21/14 06:36 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I have one of their engines, I'm still trying to deal with the sub standard workmanship, and parts they use.
Build enough engines. .........and
[Re: 71birdJ68]
#1688477
10/22/14 12:52 PM
10/22/14 12:52 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Hands down the INDY Maxx Aluminum Block and like someone else said you can not go wrong with Todd Marsh and would not be afraid to use others on the board that's a full time business. Another thing that might come into play is who now has the blocks in stock,it matters not so much as who's is best if you can not get it! ![](/ubbthreads/images/graemlins/biggrin.gif) PS I have owned 7-8 Indy Maxx blocks both RB & LD and have never had but one problem out of any of them.And that was when #5 rod broke & took out #6 rod also at 7400 RPM... long story short it had holes in both sides of the block.A fellow Moparts member told me of a place in Atlanta and they repaired it to where if you did not know where to look at it you could not tell it had been repaired.It also had to have 3 sleeves put in it from the damage,but it was once again in like new condition.Try doing that with a cast block. ![](/ubbthreads/images/graemlins/biggrin.gif)
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1688478
10/22/14 02:05 PM
10/22/14 02:05 PM
Posts: 1,288 Oregon
sg66mopar
Never had an Indy block so no input there. Two world blocks though. The first one came with the cylinder liners not pressed in fully. When I talked to Bill Mitchell he said the heat and torque from the head would seat them. ![](/ubbthreads/images/graemlins/confused.gif) Amazingly, that actually happened. The second one came with the lifter bushings pressed in at random heights. Also, about half of them were not indexed correctly for the oil holes to line up with the holes in the lifter body so no oil made it to the top of the pushrods. We didn't catch that until the motor was together and was galling about half of the roller rocker tips. I now have to file the lifter oil holes oblong before using them. Not bashing World, just not very good "finish" work.
[Re: sg66mopar]
#1688479
10/22/14 02:11 PM
10/22/14 02:11 PM
Al_Alguire
Las Vegas
Well my lifter bushings ended up getting replaced as we went with Jesel keyways. Never actually checked the ones that it came with as we were not ever going to use them. Took awhile to get them from Jesel but now we can starting doing some grinding and screening to get the valley ready to go.
[Re: Al_Alguire]
#1688480
10/22/14 02:17 PM
10/22/14 02:17 PM
Posts: 503 Idaho
1320Dart
Idaho
Hi Al! A real dumb question here I'm sure. What are the access plugs in the lifter valley for?
Greg ----------------------------------------------------------------- Cost is irrelevant, making memories is far more valuable!
