indy maxx or world products? #1688462
10/21/14 12:51 AM
10/21/14 12:51 AM
alaska,usa
9
9secondsatellite Offline OP
alaska,usa
anyone have a preference between the 2? who would you recommend getting 1 from with machine work?
Re: indy maxx or world products? [Re: 9secondsatellite] #1688463
10/21/14 01:04 AM
10/21/14 01:04 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
1 what?
If you are asking about Hemi blocks, I would look at HP Performance blocks in Knoxville, TN. Best quality I have seen on any of the aluminum blocks and has some nice secret modifications to it as well.
Jerry
Old Geezer Racing
Re: indy maxx or world products? [Re: SCATPACK 1] #1688464
10/21/14 01:07 AM
10/21/14 01:07 AM
1 what?
Jerry
And they don't have any and won't for awhile.
Re: indy maxx or world products? [Re: ] #1688465
10/21/14 01:52 AM
10/21/14 01:52 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
have both here, like the indy better, alum to alum.
Re: indy maxx or world products? [Re: boatracer572] #1688466
10/21/14 01:58 AM
10/21/14 01:58 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
And I went with World. Either way you decide to go DO NOT get it finished machine. IMO there I s no such thing. I would prefer to get one blank with no lifter holes even. But it depends on your application but certainly do not go with a "finished" machined piece.
Re: indy maxx or world products? [Re: Al_Alguire] #1688467
10/21/14 02:37 AM
10/21/14 02:37 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I always questioned the "Finished honed" to so and so spec.............? As I learned, you measure pistons then final hone to size cos a matched set can still be out of wack from biggest to smallest plus who`s gonna grind on a piston to make it fit.
Re: indy maxx or world products? [Re: Thumperdart] #1688468
10/21/14 11:57 AM
10/21/14 11:57 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I personally think the Indy block is a stronger piece. Compare the valley and main web area on them both and you will see what I mean.
Re: indy maxx or world products? [Re: Al_Alguire] #1688469
10/21/14 12:44 PM
10/21/14 12:44 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I thought you used aHP block on your predator.
Re: indy maxx or world products? [Re: 9secondsatellite] #1688470
10/21/14 01:01 PM
10/21/14 01:01 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I bought the World block. So far I am satisfied with it.
We are Not near the HP levels of some here though.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: indy maxx or world products? [Re: supercomp] #1688471
10/21/14 02:47 PM
10/21/14 02:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Nope I do have an HP block sitting in Colorado I have not even picked up yet though.
Re: indy maxx or world products? [Re: Al_Alguire] #1688472
10/21/14 03:09 PM
10/21/14 03:09 PM
alaska,usa
9
alaska,usa
thanks for the input guys. sorry, i should have specified rb block. i'm in alaska so machine work is somewhat limited. i could have whoever i get the block from also provide the pistons so they can do the finish on the bores and the lifter boss.if i wanted to go this route and use the indy block, who would be a good choice for this?
Re: indy maxx or world products? [Re: 9secondsatellite] #1688473
10/21/14 04:59 PM
10/21/14 04:59 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I would contact Todd Marsh.
Re: indy maxx or world products? [Re: SCATPACK 1] #1688474
10/21/14 05:06 PM
10/21/14 05:06 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have one of their engines, I'm still trying to deal with the sub standard workmanship, and parts they use.
Re: indy maxx or world products? [Re: 71birdJ68] #1688475
10/21/14 06:36 PM
10/21/14 06:36 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Build enough engines. .........and
Re: indy maxx or world products? [Re: camastomcat] #1688476
10/22/14 02:25 AM
10/22/14 02:25 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
And what?
Re: indy maxx or world products? [Re: 71birdJ68] #1688477
10/22/14 12:52 PM
10/22/14 12:52 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Hands down the INDY Maxx Aluminum Block and like someone else said you can not go wrong with Todd Marsh and would not be afraid to use others on the board that's a full time business.
Another thing that might come into play is who now has the blocks in stock,it matters not so much as who's is best if you can not get it!
PS I have owned 7-8 Indy Maxx blocks both RB & LD and have never had but one problem out of any of them.And that was when #5 rod broke & took out #6 rod also at 7400 RPM... long story short it had holes in both sides of the block.A fellow Moparts member told me of a place in Atlanta and they repaired it to where if you did not know where to look at it you could not tell it had been repaired.It also had to have 3 sleeves put in it from the damage,but it was once again in like new condition.Try doing that with a cast block.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: indy maxx or world products? [Re: MRMOPAR622] #1688478
10/22/14 02:05 PM
10/22/14 02:05 PM
sg66mopar Offline
sg66mopar  Offline
Never had an Indy block so no input there.
Two world blocks though. The first one came with the cylinder liners not pressed in fully. When I talked to Bill Mitchell he said the heat and torque from the head would seat them. Amazingly, that actually happened.
The second one came with the lifter bushings pressed in at random heights. Also, about half of them were not indexed correctly for the oil holes to line up with the holes in the lifter body so no oil made it to the top of the pushrods. We didn't catch that until the motor was together and was galling about half of the roller rocker tips.
I now have to file the lifter oil holes oblong before using them.
Not bashing World, just not very good "finish" work.
Re: indy maxx or world products? [Re: sg66mopar] #1688479
10/22/14 02:11 PM
10/22/14 02:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well my lifter bushings ended up getting replaced as we went with Jesel keyways. Never actually checked the ones that it came with as we were not ever going to use them. Took awhile to get them from Jesel but now we can starting doing some grinding and screening to get the valley ready to go.
Re: indy maxx or world products? [Re: Al_Alguire] #1688480
10/22/14 02:17 PM
10/22/14 02:17 PM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Hi Al!
A real dumb question here I'm sure. What are the access plugs in the lifter valley for?
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: indy maxx or world products? [Re: Al_Alguire] #1688481
10/22/14 02:22 PM
10/22/14 02:22 PM
San Jose Ca.
San Jose Ca.
Those bushings look simular to the ones I had Che make for me...
