Problem Installing Door Window Mech 71 Charger #1688374
10/20/14 07:52 PM
10/20/14 07:52 PM
Upstate New York
archie340 Offline OP
Upstate New York
Seems no matter what I do the rear white plastic slider extends to far out of the groove causing it to jam like the track is to short. I replaced the white slider and lubed the mechanism but it has not fixed the problem.
I had no problem with the other door, the slider would extend past the groove but go back in as the window is rolled up. Any help would be appreciated. Thanks
Re: Problem Installing Door Window Mech 71 Charger [Re: archie340] #1688375
10/21/14 11:51 AM
10/21/14 11:51 AM
pa.
dan9 Offline
dan9  Offline
pa.
Can you flip that arm 180 degrees?
