Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #2063086
04/27/16 11:40 PM
04/27/16 11:40 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
What side clearance are you setting the rockers at? Too much clearance will also drop oil pressure. I shoot for 0.015 inches and make sure a 0.020 inch shim don't fit. I use a u shaped SS shim.
Re: Harland Sharp rockers and now low oilpressure... [Re: markz528] #2063468
04/28/16 04:35 PM
04/28/16 04:35 PM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
I run a .065 restrictor in the tee before going to each head. Tried a .075 and immediately flooded the heads and pushed raw oil out the breathers. I run 400 seat pressure, 1.6 HS rockers .810 lift with NO problems for years.
RIP
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #2063532
04/28/16 07:03 PM
04/28/16 07:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I run a .060 restrictor through the standard block oil holes but they have been drilled and fed from the galleys for full-time oiling. The top end gets loads of oil and I get 25 lbs of pressure priming with a cordless drill. I have yet to fire the motor but I think I could have afforded to go with a smaller retrictor. This is with a standard volume pump too.
Re: Harland Sharp rockers and now low oilpressure... [Re: Stanton] #2063577
04/28/16 08:11 PM
04/28/16 08:11 PM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
I used Holley carb jets (#48) to restrict the oil flow to the top end. Run 5W-30 oil. Engine oil pressure is 16-17 Psi at idle and about 70 Psi at WOT. (The jets have a 1/4-32 UNF thread)
/Tom
Re: Harland Sharp rockers and now low oilpressure... [Re: TomsCharger70] #2798863
07/20/20 10:28 AM
07/20/20 10:28 AM
Warren, MI
Miszny Offline
Miszny  Offline
Warren, MI
Thanks for this helpful thread, I did the same thing using jets...
Wanted to bring pressure from 20 in gear to 35 with 20w50 oil. Turned out that 69 jet was perfect fit.
