Hemi oil consumption #1687484
10/18/14 06:55 PM
10/18/14 06:55 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
If you are a regular on this site, you may remember my post about the thrash to seal the intake on my HEMI over labor day weekend, (Thanks Greg at Superformance!) To review, I had oil usage of roughly a quart every 100 miles. The fix ended up using superformance gaskets, (that stopped the "wick" of oil through the gaskets) coupled with studding the intake, light application of "Hondabond" and torqueing the studs to 125 inch pounds vs. the 72 in lb. factory recommended. I just finished my second trip, (won top 5 at the show and won $100.00) and oil level is down, SLIGHTLY. About 200 miles. I understand that the HEMI is going to use some oil, but not a quart every 100 miles!
! [Re: Hemi ragtop] #1687485
10/18/14 06:59 PM
10/18/14 06:59 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That's great news! I remember you were pretty frustrated by the ordeal.
Sheldon
Re: ! [Re: RUNCHARGER] #1687486
10/18/14 09:24 PM
10/18/14 09:24 PM
Tennessee
Tennessee
LOL, one of the responses was, "that is why we call them "HEMIROIDS"! I have never had an intake leak in dozens of engine builds, to deal with it TWICE in one build was frustrating to say the least. What I wonder is, how did the early NASCAR racers run over 500 miles at high RPMs without running out of oil? I collect old car mags. In several of them, brand new HIMIs were tested, more than one mentioned the "above average oil consumption". I have talked to old time builders that even went so far as to set the valve to guide clearance at ZERO in an effort to reduce the oil consumption. I even have an article on Dick Landy suggesting extreme measures to eliminate the problem.
Re: ! [Re: Hemi ragtop] #1687487
10/18/14 09:46 PM
10/18/14 09:46 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Hey Zig
Glad you got it fixed. Now come up to Maryville ir Knoxville next weekend and cruise with us.
Jerry
Old Geezer Racing
Re: ! [Re: SCATPACK 1] #1687488
10/19/14 12:20 AM
10/19/14 12:20 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I'm i Morristown, tell me about your cruise.
Re: ! [Re: 71birdJ68] #1687489
10/19/14 12:21 PM
10/19/14 12:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Maybe its because the exaust valve is submerged in a bath of oil, bad oil drainage?
Re: Hemi oil consumption [Re: Hemi ragtop] #1687490
10/19/14 03:40 PM
10/19/14 03:40 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Glad to hear that your problem seems to be solved. Superformance does make excellent gaskets. Just for the record not all Hemi's drink oil. I had a '66 street hemi back in '70 that became my daily driver for a few years. When I bought the car [ for $600.00 ] it had a bad right rear qtr. and a rod knocking. I replaced the rod, repaired the crank [ couldn't afford a new one ] and did a really cheap ring and bearing job on it along with an Isky cam and drove it for 50,000 miles before selling it to a friend for $500.00. As best as I can recall it used about a qt. of oil every 1,500 miles or so. Not all that bad considering the really crappy ring job. Not much talent in predicting future car prices either.
Re: Hemi oil consumption [Re: 5spdcuda] #1687491
10/19/14 10:08 PM
10/19/14 10:08 PM
Tennessee
Tennessee
My oil consumption was obvious once I pulled the intake, the ports in the hear were wet with oil and the intake gasket was saturated. The oil actually wicked through the name brand gaskets. What was frustrating was that the head/intake angle was spot on, the torque of the bolts was per factory spec, yet it still leaked. Superformance gaskets stopped the wick problem, "Honda bond" stopped the oil from passing the gaskets, and studs with the extra clamp (125 in.lb vs. 72)kept the oil where it belonged. Funny thing, once I discovered the "Honda Bond" I noticed a familiar grey material under a number of intakes on fast cars at the drag strip!
