518 only spins in reverse?
#1687439
10/18/14 04:14 PM
10/18/14 04:14 PM
Posts: 4,762 Florida
BDW
95 518 pulled from JY and installed in my 70 Challenger. This is all on jack stands with rear wheels off the ground.
None of the electronics are connected yet (neutral safety switch or OD/LU power). I have the neutral safety switch grounded so it will start in any gear. Linkage seems to be fine, shifts through the gears.
Before starting, wheels would only turn when in neutral. Park would hold the tires from spinning by hand. Added 6 qts ATF4 fluid, ran it for 2-3 min, then added 3 more qts.
With engine running, tranny in N, wheels spin in reverse, same for park. Even if I start the car in drive, it will spin the wheels forward then stop and start spinning in reverse. I can even hold down the brakes hard, it's stalls engine but doesn't stop it from spinning in reverse.
Now when I put car in park (not running) and spin the tires by hand, it spins easily and makes a clicking noise.
Never shifted tranny while running, always stopped the car, changed gears, then tried again.
Any ideas?
Re: 518 only spins in reverse?
[Re: BDW]
#1687440
10/18/14 05:14 PM
10/18/14 05:14 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you remove the shift linkage and operate the shift lever by hand does it do the same thing? Does the shift lever have distinct detents, no lost motion?
[Re: John_Kunkel]
#1687441
10/18/14 06:46 PM
10/18/14 06:46 PM
BDW
Ok, new symptoms:
I disconnected shifter linkage and moved through the spots by hand. All had good indents, although there is a "slight" indent between reverse and park? Like it has a audible click then I can push further back.
Started car in N then shifted by hand, wheels did not move no matter what position of tranny selector. Checked fluid, it was low, added 2 more qts and tried again, same thing, no movement.
Now when I start car in gear, D or R, tires will spin forward for a little bit then stop, or I can easily stop by hand.
When in park, I can't spin the tires now.
[Re: BDW]
#1687442
10/19/14 06:17 PM
10/19/14 06:17 PM
John_Kunkel
Rio Linda, CA
It's possible that the pump has failed, only way to know is to hook up a test gauge to the line pressure test port at the accumulator.
[Re: BDW]
#1687447
10/20/14 04:27 PM
10/20/14 04:27 PM
John_Kunkel
Rio Linda, CA
Again, you need to determine if the pump is putting out pressure via the gauge I mentioned earlier; if there is pressure then the likely culprit is the direct clutch in the tail.
[Re: John_Kunkel]
#1687448
10/21/14 01:15 AM
10/21/14 01:15 AM
Posts: 15,565 Omaha Ne
TJP
Omaha Ne
Thanks for your efforts John to help us with our T/F woe's, I sometimes too wonder why I bother??? Nuff SAID,
[Re: TJP]
#1687449
10/21/14 07:56 AM
10/21/14 07:56 AM
BDW
Thanks for your valuable input
