Spool type motor mounts
#1686612
10/16/14 09:11 PM
10/16/14 09:11 PM
Posts: 4,457 Washington
madscientist
Washington
Does anyone know of a spool type motor mount that is solid, not poly? I can't seem to find anything. Thanks
Re: Spool type motor mounts
[Re: Crizila]
#1686616
10/17/14 06:08 PM
10/17/14 06:08 PM
madscientist
Washington
So it would appear I am stuck with poly.
Bummer
[Re: madscientist]
#1686617
10/17/14 06:54 PM
10/17/14 06:54 PM
Posts: 5,894 Florida
Locomotion
Well, if you're really set on solid mounts and ambitious, you can always swap out the spool k-member for and sandwich type and use Moroso mounts! But that's more work than fabricating & welding the end caps on the spool mounts. One last option would be a motor plate. But that leaves a long, unsupported area between the water pump & trans mount. (Not good if the trans blows.) Poly can't be that bad. It's debatable, but I've always liked the idea of a torque strap as well so the actual block isn't stressed, even with solid mounts.
[Re: madscientist]
#1686619
10/17/14 08:30 PM
10/17/14 08:30 PM
Posts: 7,506 Az
Crizila
Az
Thought about the K-member swap too. I don't want to do that because it's still a fairly clean, stock #'s matching car (for the most part)...so I'm hesitant to do that. Guess I could keep the original...but I'd have to store it. That sucks.
I guess it's not just the poly I don't care for. I don't really like this style mount. Looks to me the only advantage is assembly at the factory. Otherwise...I can see no reason why the spool is better than the old system.
What, you think the motor only goes in at the factory??? A lot easier with the spool mounts, especially if you are leaving the trans in place. Don't really understand what your problem is?? - but - as said, weld plates on the ends of the spool mounts and you are there. No K member hassles.
Fastest 300
[Re: Crizila]
#1686620
10/17/14 08:35 PM
10/17/14 08:35 PM
madscientist
Washington
So are you saying the spool system is better, or just easier to R&R?
For the record..I don't care for poly anything. Have a poly trans mount and don't like how it fit. So for the engine I would rather have it solid. Guess I can weld it.
Or, maybe I should machine up some solid ones, then have them CNC'd and make millions.
[Re: madscientist]
#1686621
10/17/14 11:14 PM
10/17/14 11:14 PM
Posts: 7,506 Az
Crizila
Az
Easier for sure as far as R&R goes - and that alone makes it better IMO. Poly mounts allow very little movement, but still allow for some misalignment. IMO, they are a good compromise. BTW, if you go with solid engine mounts, I suggest you do the same with the trans mount. Hope you got a well reinforced frame ( reads no twisty ) to go along with those solid mounts. Some extra Polident on them choppers might be warranted too.
Fastest 300
