Engine noise #1686293
10/15/14 09:29 PM
10/15/14 09:29 PM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
A question for you engine guys out there. I have a 1970 383 motor that when it reaches operating temp, I get a tapping noise. The motor does not overheat....
Any thoughts or ideas would be appreciated.
Re: Engine noise [Re: jrp16] #1686294
10/15/14 11:13 PM
10/15/14 11:13 PM
usa
smos001 Offline
smos001  Offline
usa
possibly a bad Hydraulic lifter. upload a sound clip. that may help people diagnose.
Re: Engine noise [Re: jrp16] #1686295
10/15/14 11:21 PM
10/15/14 11:21 PM
Welcome aboard! recent problem or always been there? aftermarket cam/lifters (what is your preload?). Plenty of oil pressure? any other valve train changes? Press straight down vertical on the lifter end of each rocker arm with a wooden hammer handle while idling & a bad one will get quieter/change tone. Holler back when you can
Re: Engine noise [Re: smos001] #1686296
10/15/14 11:22 PM
10/15/14 11:22 PM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
The lifters were changed out... I will work on getting a sound clip uploaded. Thanks...
Re: Engine noise [Re: jrp16] #1686297
10/16/14 04:52 PM
10/16/14 04:52 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
An exhaust leak at the head/manifold sounds very much like a tappet.
Re: Engine noise [Re: dynorad] #1686298
10/16/14 11:12 PM
10/16/14 11:12 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
Re: Engine noise [Re: JonC] #1686299
10/17/14 04:38 PM
10/17/14 04:38 PM
Arizona
jrp16 Offline OP
jrp16  Offline OP
Arizona
Thank you all for your input... I will let everyone know what I find. Thanks again....
Re: Engine noise [Re: jrp16] #1686300
10/18/14 10:23 PM
10/18/14 10:23 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
IF you determine that its not an exhaust leak, and if you check the lifters - I would also check the oil pressure.
Additionally if it is a lifter and you cant pin it dowm someone with an old occiliscope might be able to help.
Couple of things to report back with -
Mechanically checked oil pressure hot and cold.
Stock cam and lifters?
Stock stamped rockers or adjustable?
Stock or HP or HV oil pump?
Has it always been there or just started?
