Page 5 of 5 1 2 3 4 5
Re: What is Proper Valvetrain Geometry? [Re: Crizila] #1685590
10/17/14 08:45 PM
10/17/14 08:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I'm still trying to figger out what 50% at 90* means, explain please.
Re: What is Proper Valvetrain Geometry? [Re: cudaman1969] #1685591
10/17/14 10:12 PM
10/17/14 10:12 PM
USA
B3RE Offline
B3RE  Offline
USA
On a roller rocker, at 50% of net valve lift, the geometric line from the centerline of the rocker shaft to the centerline of the roller axle should be at 90* to the valve stem. Not the centerline of the shaft to the tip of the valve as some have stated, and as a shoe type rocker is measured.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: What is Proper Valvetrain Geometry? [Re: B3RE] #1685592
10/17/14 10:19 PM
10/17/14 10:19 PM
USA
B3RE Offline
B3RE  Offline
USA
Oh, one more thing. The adjuster angle and pivot location should be 90* at 50% also, but is built into the rocker and is what it is. You work with what you have.
Mike Beachel
Re: What is Proper Valvetrain Geometry? [Re: B3RE] #1685593
10/17/14 10:39 PM
10/17/14 10:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have to ask, B3R3 are you the guy that was selling a rocker correction kit?
Re: What is Proper Valvetrain Geometry? [Re: Quicktree] #1685594
10/17/14 11:09 PM
10/17/14 11:09 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: What is Proper Valvetrain Geometry? [Re: Hemi Allstate] #1685595
10/17/14 11:12 PM
10/17/14 11:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: What is Proper Valvetrain Geometry? [Re: B3RE] #1685596
10/18/14 12:17 AM
10/18/14 12:17 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thank you for the explantion, just trying to follow thru all the BS. Just got my first Hemi and would like to check out this process on the build up.
Re: What is Proper Valvetrain Geometry? *DELETED* [Re: cudaman1969] #1685597
10/21/14 09:55 PM
10/21/14 09:55 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Post deleted by polyspheric
Boffin Emeritus
Re: What is Proper Valvetrain Geometry? [Re: polyspheric] #1685598
10/21/14 10:15 PM
10/21/14 10:15 PM
Tucson AZ,
MadMopars Online content OP
MadMopars  Online Content OP
Tucson AZ,
It isn't, and you can't.
Can you expand on this?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: What is Proper Valvetrain Geometry? [Re: MadMopars] #1685599
10/21/14 11:12 PM
10/21/14 11:12 PM
USA
B3RE Offline
B3RE  Offline
USA
Yes, I'm curious. Isn't what, and can't what?
Mike Beachel
Re: What is Proper Valvetrain Geometry? *DELETED* [Re: MadMopars] #1685600
10/22/14 11:33 AM
10/22/14 11:33 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: What is Proper Valvetrain Geometry? [Re: polyspheric] #1685601
10/22/14 12:55 PM
10/22/14 12:55 PM
Tucson AZ,
Tucson AZ,
I read the post. Jim Miller did it, it can be done. Regarding the patent and so on, I read that too.
Re: What is Proper Valvetrain Geometry? [Re: Monte_Smith] #1685602
10/22/14 09:53 PM
10/22/14 09:53 PM
gregsdart Offline
gregsdart  Offline
i'll bet correcting my geometry will not net anywhere near 46hp with my current combo. that would put me near 700hp with a small flat tappet cam.
If it helps you 2 hp and only costs a little time it is worth it. Free power is free power.
This can go right along with "nah, I don't degree my cams, its probably close enough"........Im only bracket racing.................... and all those other things that are "close enough".
This is also the reason that stockers with cast intakes, thermo-quads, stock unported iron heads and various other things will embarrass most guys aluminum headed, big cam "race" motors on the track. Its called attention to detail and getting what you can out of a combo.
Monte
Warren Johnson story
Observer, watching Warren test different belts to drive accessories.
"That is probably worth no more than a 1/4 hp, if at all"
Warren;
Maybe, but if I find one hundred things that produce a 1/4 hp, I have gained 25"
Re: What is Proper Valvetrain Geometry? [Re: gregsdart] #1685603
10/23/14 08:23 AM
10/23/14 08:23 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Monte
Warren;
thats why stocker motors cost so much, thats why I bracket race.
Re: What is Proper Valvetrain Geometry? [Re: Quicktree] #1685604
10/23/14 08:26 AM
10/23/14 08:26 AM
Q
Quicktree Offline
Quicktree  Offline
Q
but my offer still stands, any builder that can guarantee 46hp by correcting geometry I am in. will chassis dyno the car before and after. and before and after track tests. .2 for a few hundred bucks will be the best bang for the buck ever spent.
