Re: What is Proper Valvetrain Geometry?
[Re: cudaman1969]
#1685591
10/17/14 10:12 PM
10/17/14 10:12 PM
Posts: 561 USA
B3RE
USA
On a roller rocker, at 50% of net valve lift, the geometric line from the centerline of the rocker shaft to the centerline of the roller axle should be at 90* to the valve stem. Not the centerline of the shaft to the tip of the valve as some have stated, and as a shoe type rocker is measured.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
[Re: B3RE]
#1685592
10/17/14 10:19 PM
10/17/14 10:19 PM
Posts: 561 USA
B3RE
USA
Oh, one more thing. The adjuster angle and pivot location should be 90* at 50% also, but is built into the rocker and is what it is. You work with what you have.
Mike Beachel
[Re: Hemi Allstate]
#1685595
10/17/14 11:12 PM
10/17/14 11:12 PM
Quicktree
[Re: B3RE]
#1685596
10/18/14 12:17 AM
10/18/14 12:17 AM
Posts: 8,275 fredericksburg,va
cudaman1969
fredericksburg,va
Thank you for the explantion, just trying to follow thru all the BS. Just got my first Hemi and would like to check out this process on the build up.
Re: What is Proper Valvetrain Geometry? *DELETED*
[Re: cudaman1969]
#1685597
10/21/14 09:55 PM
10/21/14 09:55 PM
Posts: 4,206 New York
polyspheric
New York
Post deleted by polyspheric
Boffin Emeritus
[Re: polyspheric]
#1685598
10/21/14 10:15 PM
10/21/14 10:15 PM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
It isn't, and you can't.
Can you expand on this?
[Re: MadMopars]
#1685600
10/22/14 11:33 AM
10/22/14 11:33 AM
polyspheric
New York
Boffin Emeritus
[Re: Monte_Smith]
#1685602
10/22/14 09:53 PM
10/22/14 09:53 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
i'll bet correcting my geometry will not net anywhere near 46hp with my current combo. that would put me near 700hp with a small flat tappet cam.
If it helps you 2 hp and only costs a little time it is worth it. Free power is free power.
This can go right along with "nah, I don't degree my cams, its probably close enough"........Im only bracket racing.................... and all those other things that are "close enough".
This is also the reason that stockers with cast intakes, thermo-quads, stock unported iron heads and various other things will embarrass most guys aluminum headed, big cam "race" motors on the track. Its called attention to detail and getting what you can out of a combo.
Monte
Warren Johnson story
Observer, watching Warren test different belts to drive accessories. "That is probably worth no more than a 1/4 hp, if at all" Warren; Maybe, but if I find one hundred things that produce a 1/4 hp, I have gained 25"
[Re: gregsdart]
#1685603
10/23/14 08:23 AM
10/23/14 08:23 AM
Quicktree
Monte
thats why stocker motors cost so much, thats why I bracket race.
