hemi intake #1685108
10/13/14 01:09 AM
10/13/14 01:09 AM
iowa
copchaser Offline OP
iowa
I'm building a 633 hemi. I'm looking at the Stage V 10 bolt heads. Does any buddy offer a carburated intake for those heads. Indy's 10 bolt intake is a differant pattern. A custom sheet metal manifold is out of my budget. Thanks!
Re: hemi intake [Re: copchaser] #1685109
10/13/14 10:39 AM
10/13/14 10:39 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
If you have both 16 and 10 bolt pattern on the heads you can use the stg v adapter plates and use any conventional hemi manifold out there.
Re: hemi intake [Re: dthemi] #1685110
10/13/14 12:35 PM
10/13/14 12:35 PM
iowa
iowa
The heads I'm looking at are the millennium heads. If I go with the adaptor plates will that hurt the flow benefits of the millennium head? Are those plates a mickey mouse deal? My other option is the 10 bolt INDY heads. I'm real sold on there cast is rocker pedestals. How are the Indy rockers arms? I'm fairly set on going the 10 bolt intake route. Thanks again.
