Re: 15 inch rims on a stock 97 ram?
[Re: Polarapete]
#1684725
10/13/14 06:15 PM
10/13/14 06:15 PM
Posts: 15,487 Florida
scratchnfotraction
I can't see why anyone would want to go with a smaller rim than was stock ![](/ubbthreads/images/graemlins/shruggy.gif) The very nature of our trucks (in daily use, as a truck) is to be used to capacity and not hobbled by undersized rubber and besides they look dumb with a small tire in a huge wheel well
I run a NV4500 5 speed 3.55 235 75/15 and get good mpg and performance is great for fast hole shots running a whiplash roller cam in my 85 stepside.
the 94 ram with 16" 265/75/15 is a little tall for the 3.55 nv3500 5 speed. so the 15" 235s put some zip into the wore out mag 318/3500.
yes they are small in those huge wheel openings. but we plan to slam it down with a flip flop on the rear axle then tub the bed for 12" wide rim with 33x21.50x15 M/Ts
for now my son piglet is doing the 1 wheel peel with the goofy looking little tires with a big smile. ![](/ubbthreads/images/graemlins/laugh2.gif)
we run what we brung ![](/ubbthreads/images/graemlins/drive.gif)
[Re: scratchnfotraction]
#1684726
10/14/14 04:19 AM
10/14/14 04:19 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
OK, I am running some 15" M/T Sportsmans on the front of the race truck and they look dinky.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1684728
10/14/14 12:09 PM
10/14/14 12:09 PM
scratchnfotraction
thats the way my skinnys looked with a 165/15 tire but once the front drops it looks way better fattys & drag skinnys. I see a lot of ram low rider trucks around here with 10 inch wide rims running the 195/50/15 all 4 corners ![](/ubbthreads/images/graemlins/shruggy.gif) looks way better than the long bed c10 chebbys with 13" wire spoke low riders with a 185/80/13 tire ![](/ubbthreads/images/graemlins/eeek.gif) I guess it boils down to what "LOOK" you want when stylin around token on a # and diggin on the radio. ![](/ubbthreads/images/graemlins/smoke.gif)
