Thrust Bearing Failure #1684390
10/11/14 12:01 AM
10/11/14 12:01 AM
florida,usa
rdakota340 Offline OP
florida,usa
I could not find my old post. So anyway built motor it ate the thrust bearing with in 300 miles and the crank was junk.I had done some checking found out that the -6 fitting I used was restricting the cooler flow and pushing the converter forward so took the tranny apart and drilled the cooler circuit out to 1/4"NPT to -8 line thought that was fix turns out it didn't. Bought new crank "Scat" got motor back in drove it 100 miles check the end play it has.037 so it too is wearing the bearing again, Well I finally talk to someone the builds a lot of trannys and big block mopars. He ask for all my clearances and when I told him I had 1/8" between converter and flex plate he said that's my problem he has always had 3/16" to a 1/4". I told him my input endplay was .012" he said that too is a problem I need more and yes I looked it up and there should be .036" to .084". I'm working on checking to see if the crank is ok tomorrow if so then I hope to have it running in two weeks so we shall see!
Turbos The Only Power Adder!
Re: Thrust Bearing Failure [Re: rdakota340] #1684391
10/11/14 12:21 AM
10/11/14 12:21 AM
Is the old crank cast iron or forged steel? The reason I'm asking is I've had more than one forged steel crankshaft thrust surface repaired and return to service with good results Lots of gremlins out there, they all live with Mr Murphy and hate car guys
Re: Thrust Bearing Failure [Re: rdakota340] #1684392
10/11/14 12:21 AM
10/11/14 12:21 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Thanks for that update.
Sheldon
Re: Thrust Bearing Failure [Re: rdakota340] #1684393
10/11/14 02:32 PM
10/11/14 02:32 PM
florida,usa
florida,usa
These are both Scat cranks!
Re: Thrust Bearing Failure [Re: rdakota340] #1684394
10/11/14 07:22 PM
10/11/14 07:22 PM
florida,usa
florida,usa
Can scat crank be welded up on the thrust surface.
Re: Thrust Bearing Failure [Re: rdakota340] #1684395
10/11/14 10:45 PM
10/11/14 10:45 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Randy did you get my PM?
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Thrust Bearing Failure [Re: dusturbd340W5] #1684396
10/12/14 12:16 AM
10/12/14 12:16 AM
florida,usa
florida,usa
Yes I sent you a one back!
Re: Thrust Bearing Failure [Re: rdakota340] #1684397
10/12/14 09:30 PM
10/12/14 09:30 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Having the same problem. 3 converters, two flexplates. Now I'm doing trans,cooler, lines. .002-.015 in 200 miles no passes. Forged scat sb crank. Should take care of it.
Re: Thrust Bearing Failure [Re: 1980volare] #1684398
10/13/14 10:58 PM
10/13/14 10:58 PM
florida,usa
florida,usa
Wow I'm not the only one with a scat crank having this problem. I called scat today and let them know what happen and they wanted pictures so I sent them a few today so I hope they can figure something out.
Re: Thrust Bearing Failure [Re: rdakota340] #1684399
10/15/14 10:38 PM
10/15/14 10:38 PM
florida,usa
florida,usa
Did some checking and found the pilot snout on the converter is bottoming out before the pads touch the flex, So is this my problem?
Re: Thrust Bearing Failure [Re: rdakota340] #1684400
10/15/14 11:00 PM
10/15/14 11:00 PM
Kissimmee Fl.
Kissimmee Fl.
in one word yes
Re: Thrust Bearing Failure [Re: rdakota340] #1684401
10/15/14 11:28 PM
10/15/14 11:28 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
Had same problem. Converter hub was bottoming/ballooning out on crank. I put .025 shim between crank and flexplate and .025 shims between flexplate pads and converter. You want as much clearance as possible between converter hub and the crank. With engine out of the car I bolted the converter up with flexplate on and used clay to determine clearance between converter hub and the crank. You could also use a small wad of aluminum foil to determine clearance. Without the shims it had ZERO clearance. Solved my problem...hope this helps..
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Thrust Bearing Failure [Re: steve660] #1684402
10/15/14 11:34 PM
10/15/14 11:34 PM
florida,usa
florida,usa
Well I'm going to sent the converter back and have it fixed for more clearance.
Re: Thrust Bearing Failure [Re: rdakota340] #1684403
10/15/14 11:42 PM
10/15/14 11:42 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
That should help. While my crank was out i had in machined for more clearance for the converter hub, but it still bottomed out. Sometimes aftermarket cranks and converters don't fit together right. I always check the clearance if im trying a a diff converter. Tearing out thrust bearings SUX!!!
Re: Thrust Bearing Failure [Re: dusturbd340W5] #1684404
10/15/14 11:48 PM
10/15/14 11:48 PM
florida,usa
florida,usa
in one word yes
Woody I tried to call you earlier after I check it,call me tomorrow, Both converters bottomed out in the pilot the FTI converter is .36 taller than a stock converter and .18 taller than the Hughes converter but the stock converter is just even with the bottom of the pilot hole.
Re: Thrust Bearing Failure [Re: rdakota340] #1684405
10/16/14 08:48 PM
10/16/14 08:48 PM
florida,usa
florida,usa
Did some checking today and found that there is a .40''gap between converter pads and flex plate so the snout needs to be cut down .100 to get my clearance and hope this fixes it.
