Re: looking at a 98 dodge 2500 v10 4x4 what to look for
[Re: SuperStockWagon]
#1684294
10/11/14 01:24 PM
10/11/14 01:24 PM
Posts: 6,021 Salem
Grizzly
Moparts Proctologist
Salem
I'll back you on that. ![](/ubbthreads/images/graemlins/beer.gif) We had a '96 V10 auto 2wd that could do 15mpg all day on the highway. Around town though it was heavy on fuel. An honest Dodge salesperson I know told me at the time the difference in fuel mileage between the 3.9, 318, 360, and V10 was 1mpg. ![](/ubbthreads/images/graemlins/Twocents.gif)
Mo' Farts
Moderated by "tbagger".
[Re: HotRodDave]
#1684300
10/13/14 06:13 PM
10/13/14 06:13 PM
Posts: 20,720 in a cattle trailer down by th...
Guitar Jones
I had a 96 2WD dually that got 10 MPG. Didn't matter what you did or how you drove it, it just got 10. I did love that truck but it was originally from Minnesota so it was starting to have some rust issues so it had to go.
[Re: chargers777]
#1684303
10/18/14 04:51 PM
10/18/14 04:51 PM
Guitar Jones
went ahead and bought it.Truck was much better shape than described.The cats though are rattling and there is a driver side manifold leak.I hope its the exhaust but I here what sounds like possible rod bearing noise.I hope not but can the pan be dropped in the truck and the bearings changed?
There was a TSB out on them to separate the #7 and #9 cylinder plug wires so they don't run together in the loom. Crossfire between the two (like a V8 does #5 and #7) was causing a lean condition and burning the piston. If it gets bad enough it can score the cylinder wall. Hope that's not the case for you.
[Re: Guitar Jones]
#1684304
10/21/14 04:24 PM
10/21/14 04:24 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I like the idea of the V10 a lot. I had 2002 CTD and I liked it too, but it was heavy on the maintenance end and I never drove it enough to make it pencil out. For what I need (no commuting and occasional heavy towing) a V10 would be great. There is a V10 1 ton 2wd dually QC in my area on CL that looks like a cream puff with low miles and I need to check it out. Glad to hear about the TSB and if I bought the first thing I would do would be a custom set of wires and careful routing.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1684305
10/24/14 10:18 PM
10/24/14 10:18 PM
Posts: 3,427 PA
PLATINUM6BBL
PA
Look for disappearing anti-freeze. My '98 V10 QC SB 5spd 4x4 had the cracked head issue. Started reporting lose of anti-freeze when it had upper 20k's and had the head replaced under warranty at around 40k. I did gasket match the plenum, intake, heads and exhaust manifolds before it was all buttoned back together. That truck got 15 highway, 12 town and 10 towing no matter what. My '95 V10 RC LB 5spd 4x4 got 16-18 highway and 13 town / towing / emergency response.
1969-1/2 A12 LOH Road Runner A4 w/ M6S 13.34 at 104 PSMCDR 9/06 in Mopar Action 8/07 12.95 at 105.94 F.A.S.T. 11/06
[Re: PLATINUM6BBL]
#1684306
10/27/14 02:41 PM
10/27/14 02:41 PM
Posts: 4,595 Motor City
6PKRTSE
Motor City
My 96' 2500 V10 4X4 has been an awesome truck. It has 154,000+ on it now & has been virtually trouble free. Only replaced, recently front axle u-joint, rotors, brakes & T stat housing from plastic to upgraded newer alum housing due to a crack, belt tensioner, belt & still on second battery. All else is still all original parts. In Michigan though, so it it going to rust off of the frame within the next few years.....
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
