HID headlight question #1684220
10/10/14 02:13 AM
10/10/14 02:13 AM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Putting my new HD headlights in my 98 Ram. Plugged everything up but no high beams. The plug that goes into the old headlight holder only has two wires- the headlight plug on the truck has three. How do these things go bright???
Re: HID headlight question [Re: Carsavior] #1684221
10/10/14 03:08 AM
10/10/14 03:08 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
The cheaper kits generally don't have a high beam. The bulb is only one wattage. Sounds like you need a bi-xenon kit, which moves the position of the bulb to create a simulated high beam. That's what is in my Dakota and works well.
This explains the difference. http://www.ebay.com/gds/Difference-Betwe...19653525/g.html
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: HID headlight question [Re: herkamer] #1684222
10/10/14 04:29 AM
10/10/14 04:29 AM
Monroe, LA USA
Monroe, LA USA
Sounds like my situation. Cheap maybe but not inexpensive! Can you replace just the bulb and splice into the high beam wire to get high beams?
Re: HID headlight question [Re: Carsavior] #1684223
10/10/14 11:41 AM
10/10/14 11:41 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
No, it has a whole separate controller and motorized bulb to emulate high. I found that I never really needed it, even out in the middle of dark mountain roads. Mine were plenty bright on low.
Matt
69 Dart Swinger 340
and even more
Re: HID headlight question [Re: herkamer] #1684224
10/10/14 11:56 AM
10/10/14 11:56 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Beware the cheapo kits, they use a cheap, inferior bulb that emits
radiation which will degrade the reflective surface of your OE housing. DAMHIK!!!
Joe
Re: HID headlight question [Re: Carsavior] #1684225
10/10/14 12:51 PM
10/10/14 12:51 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I've been saving up for these:
http://shop.retroshop.us/ProductDetails.asp?ProductCode=2G.RAM.RETRO
Are these the ones you're having trouble with?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: HID headlight question [Re: 3hundred] #1684226
10/10/14 02:12 PM
10/10/14 02:12 PM
Monroe, LA USA
Monroe, LA USA
Look like that but they have a row of LEE'S between headlight and turn signal. They are one piece tho.
