Re: header options for A body with Edelbrock 440 Victor
[Re: sixpackgut]
#1683865
10/09/14 07:31 PM
10/09/14 07:31 PM
Posts: 755 Rochester, PA (near Pittsburgh...
1974 474 Duster
If you can wait until the weekend I can take some pics of my Duster. It has a low deck block,1but I have 440-1 heads. The headers are TTI 2" to2 1/8" step headers. Fit extremely well on my car. They make them for Rb deck heights as well. Thanks, Ken
[Re: 340KID]
#1683866
10/09/14 10:30 PM
10/09/14 10:30 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
What are the header options for Abody with 440 Victor heads, stock front suspension but drag race only. Engine will be a 493 with approx. 700HP going in a 1973 Scamp
Does anyone make them ?
You can make your own and have it welded for you.Do you have the fender cut out?Or want under chassis?
[Re: sixpackgut]
#1683872
10/12/14 10:28 AM
10/12/14 10:28 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
[url=http://s40.photobucket.com/user/sixpackgut/media/barracuda064.jpg.html] I have these for sale in race parts
sixpackgut,
I was seriously considering these same headers for my Cuda. My engine is set back a couple of inches. Still using the stock firewall though, but I was worried I would hit the back of the outer fender wells with them. The other issue is that I am running a 4 speed and the linkage can be a pain.
Right now I am running an original set of the proparts headers and they fit, barely. I know I am leaving a bunch of power on the table with them and plan on upgrading soon.
Do you have any pictures of these headers from the side where the tubes run down along the back of the fenders/floor pan. Sorta like the one in your picture above, but a little closer up. The floor pan seam right by the collectors can be folded over I believe. It might give me a little more room for them. Also do you have any pics of the drives side in the same area?
Also, I am running a low deck with 440-1 heads.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: GTSDave]
#1683873
10/13/14 01:52 AM
10/13/14 01:52 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
340KID I'm the friend of Mopar65 that has the duster with the procomp heads on my 440. I have the 2" hooker super comp fenderwells and they a little tight in 2 places. My lightweight master cylinder is about an inch away from the tubes at its closest point on the drivers side. The passenger side header required a little massaging on the tubes around the shock tower. Also had to do a little trimming on the inner fender sheetmmetal near the shock area.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
