Re: T&D vs Harland Sharp on a 440-1
[Re: onefastindy]
#1683001
10/07/14 10:53 AM
10/07/14 10:53 AM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
I had T&D's on mine, for some reason I had major problems with lifters and pushrods. Switched to HS and the problems disappeared. I have also used Indy rockers, were fine in my use for about three years, then started to break, and Ersons which worked great until my own stupidity broke one and you couldn't get any spares. I think I have used the HS for at least six years now and they'r still going strong.
Plynouth VIP '67 TT IC EFI
[Re: onefastindy]
#1683002
10/07/14 11:27 AM
10/07/14 11:27 AM
Posts: 449 Hampton,Va
QuickDart 502
Hampton,Va
I run both with no problems. I run the Indy rockers and broke several they dont even sell those pieces of junk anymore. I switched to the HS with a large roller cam with a lot of open pressure and run those for several years with no problems. I switched to T&D on this engine combo with the F2 30psi boost with no issues. I like them both.
[Re: Cab_Burge]
#1683004
10/07/14 04:45 PM
10/07/14 04:45 PM
Posts: 6,295 U.S.
moparniac
U.S.
Both good IMO , had Harland's on Indy EZs and now TDs on my -1s
Mopar Performance
[Re: KOS]
#1683006
10/07/14 10:35 PM
10/07/14 10:35 PM
Harlands are the answer--call Todd Marsh get some for a deal--run them until you retire then sell them--T&D is overpriced and if you ever need a spare --they are the worst for time frame--if you want real shaft rockers which are the very best forget T&D and go Jesel--the industry leader by far--fantastic stock and service with zero issues when installed right For most folks Harlands are best answer Call Todd he is in your hood
