Cam install tool #1682852
10/06/14 10:39 PM
10/06/14 10:39 PM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
Anyone know of a cam install tool specific to big block mopars?
I'd prefer not to buy a $150 tool that works on a all engines as I dont work on anything else but B engines.
I suppose I could make one but dont have lathe access
Re: Cam install tool [Re: NTOLERANCE] #1682853
10/06/14 10:49 PM
10/06/14 10:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Just use a really long bolt (or bolts if it's a 3 bolt).
No need for an expensive tool. All you need is a good hold to guide the cam so it doesn't ding the bearings.
Re: Cam install tool [Re: NTOLERANCE] #1682854
10/06/14 10:49 PM
10/06/14 10:49 PM
Me too, no parts house here rents one. cam bearing installation (adjustable) tool. there's gotta be a good backyard solution
Re: Cam install tool [Re: RapidRobert] #1682855
10/06/14 10:51 PM
10/06/14 10:51 PM
Madison Wi
Madison Wi
SOOORRRY -
I meant cam BEARING install tool..
Sheesh....what the heck was i typing....
Re: Cam install tool [Re: NTOLERANCE] #1682856
10/06/14 11:15 PM
10/06/14 11:15 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
$50.00 and you can rent it to your buddies because it will work on anything
http://www.amazon.com/Lisle-18000-Univer...stallation+tool
Re: Cam install tool [Re: Dcuda69] #1682857
10/07/14 12:35 AM
10/07/14 12:35 AM
Dcuda is the man I'm gonna get one
Re: Cam install tool [Re: Dcuda69] #1682858
10/07/14 02:38 AM
10/07/14 02:38 AM
Madison Wi
Madison Wi
I even looked on amazon and somehow missed this. Thanks
Re: Cam install tool [Re: NTOLERANCE] #1682859
10/07/14 01:44 PM
10/07/14 01:44 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
great buy
MLR426
Re: Cam install tool [Re: RapidRobert] #1682860
10/07/14 10:38 PM
10/07/14 10:38 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
lol...even a blind squirrel finds a nut once in a while!
Re: Cam install tool [Re: Dcuda69] #1682861
10/07/14 10:40 PM
10/07/14 10:40 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Must have been a run on them. There were 11 available yesterday.
Now 147+
Re: Cam install tool [Re: Dcuda69] #1682862
10/07/14 10:58 PM
10/07/14 10:58 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
lol...even a blind squirrel finds an acurn ever now andd agin!
There ya go, I fixed it for ya.
Since most of the time I am gonna have machine work done to the block, even a clean and check at a minimum I usually just have the machine shop knock them in for me. Minimal expense in my view, of course I do double check their alignment when they are done.
Careful, your character's showing!
Re: Cam install tool [Re: mopar346] #1682863
10/07/14 11:13 PM
10/07/14 11:13 PM
Urbana, MD
bordin34 Offline
bordin34  Offline
Urbana, MD
I used one of those rubber expanding freeze plugs to replace the forward-most cam bearing on my 440. Worked great.
Re: Cam install tool [Re: NTOLERANCE] #1682864
10/07/14 11:44 PM
10/07/14 11:44 PM
moparx Offline
moparx  Offline
looks like $125-134 to me instead of $50?
Re: Cam install tool [Re: moparx] #1682865
10/07/14 11:48 PM
10/07/14 11:48 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
$50.00 when I posted it yesterday Sounds like some of these guys got them ordered..hopefully they'll get them
Re: Cam install tool [Re: Dcuda69] #1682866
10/08/14 01:19 AM
10/08/14 01:19 AM
RobX4406 Offline
RobX4406  Offline
Yep, there are limited quantities. When I ordered one it said 11 left. Once that special is gone, that's it.
Re: Cam install tool [Re: RobX4406] #1682867
10/08/14 03:53 AM
10/08/14 03:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That looks like the cam bearing tool I have. But I have never seen one thats specific to just bigblock Mopars like you were asking ? Ron
Re: Cam install tool [Re: 383man] #1682868
10/08/14 08:54 AM
10/08/14 08:54 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
This one is
Re: Cam install tool [Re: BigBlockMopar] #1682869
10/09/14 04:36 AM
10/09/14 04:36 AM
md
mopars4ever Offline
mopars4ever  Offline
md
well i got the cam tool today off amazon. it was a lakewood driveshaft loop. i tried calling overstock all day and only got a recording.
Re: Cam install tool [Re: mopars4ever] #1682870
10/09/14 08:32 AM
10/09/14 08:32 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's $134 now, musta got your message.
Don't be the exception.
Re: Cam install tool [Re: NTOLERANCE] #1682871
10/09/14 09:11 AM
10/09/14 09:11 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I got one of those Lisle cam bearing tool in a E bay deal years ago with several other tools that I was after.
I already had a snap on cam bearing driver from years earlier. The lisle tool looks almost exact to the snap on tool except it had rubber sleeves around the expanders and the snap on has multiple rubber o rings around it's expander.
The snap on tool was a much better easier tool to use and after 25 years of use the o rings are still good and have never given me problems or wore out.
I see Lisle provides extra rubber sleeve for each adapter and I know why, they wear out and are damaged pretty easy. I didn't like them because the seemed to swell up from oil use also. They are too easy to get slid out of place. I re sold the lisle tool.
Not saying it's a bad tool but there is difference and the snap on tool is much nicer to use. And I'm not even sure it's a "snap on" tool, I just got it from the snap on guy a long time ago.
I'll see if I can get a picture of the snap on expanders with the o rings.
