Re: Need help with a ball joint taper dimension
[Re: moparx]
#1682258
10/05/14 11:32 PM
10/05/14 11:32 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
i "think"the k727 joint has a bigger taper than the k781/783 joints, as it fits the imperial from 59-66, and those take the k778upper joint that is also common to the 74-78 c bodies and 1/2 ton trucks, which have a bigger taper than the 62-74 b&e joints. the lower screw in joint that has the same taper as the 62-74 b&e bodies is the k719. however, that screw in joint has the same threads as the upper ball joints, so it won't screw into the lower control arms that take the k727 joints because the body thread size is smaller. hope that makes it clear[as mud].........
Thanks for the info! Bummer though....
[Re: brads70]
#1682260
10/06/14 02:32 PM
10/06/14 02:32 PM
Posts: 5,388 Pikes Peak Country
TC@HP2
Pikes Peak Country
Brad, they appear that they are all 7* tapers. The K727, K781 and K783 all match tapers after checking a 7* reamer taper against a spindle and lower control arm taper that I have sitting in the garage.
FWIW, the K5108 and K6024, bolt in GM style ball joints also have 7* of taper. Using either of these and a creative body mounting method would allow the use of GM style tubular upper control arms.
Check Speedway Motors as you can sort through their ball joint catalog by taper, material, height, thread, etc.
[Re: TC@HP2]
#1682261
10/06/14 05:34 PM
10/06/14 05:34 PM
brads70
Ontario,Canada
Thanks Tony! the K727 taper might be 7degs but it's much bigger in diameter. I need it to fit in a standard E/A-Body LCA.
[Re: brads70]
#1682262
10/06/14 10:36 PM
10/06/14 10:36 PM
Posts: 19,366 north of coder
moparx
that is true about the 7* taper on most joints. the problem is as stated. the k727 is bigger in diameter than a k719. just visualize the bottom of the cone shape. it's bigger at the bottom than the top even though it is a consistant taper from top to bottom. an example of this is the upper ball joint on the early a body. it must be changed to the 73 & later style joint to use the common disc swap spindle[s] unless you use the special spacers dr. diff sells to adapt the small ball joints to the later spindles. both joints are the same taper [7*], but the early joint is smaller [the top of the cone] than the later joint[bottom of the cone]. with that being said, speedway sells 2 different reamers for ball joint/tie rod fitment. #910-89411 [7* or 1 1/2" taper per ft.] which fits most of the stuff we play with. then there is the #910-89412 [10* or 2" taper per ft.]. this is mostly used on big gm cars like 71-80 something impalas and s-10 pickups etc. lower joints. now after all this discussion, as far as i know, the taper hole is on the lower arm of the a,b,e body and in order to use the "screw in" lower joint, you would have to modify the lower arm by welding in a ball joint "ring" then use a steering arm from several years[which i don't have in front of me at this minute] which have the taper "hole" in the arm to accept the joint. with aftermarket arms you can fab up anything, so any kind of joint/spindle/steering arm combination can be concocted. i went through this mix-n-match deal several years ago coming up with something for the suspension on my 33 humpback project that would/could use commonly available items, trying to stay in the mopar parts category. it can get mighty confusing real fast. and no, my humpback is not going to be a handling machine, as it wasn't to be at the start. suspension is facinating for me, so i like to learn even if i never use the info gleaned.
[Re: TC@HP2]
#1682264
10/07/14 07:11 PM
10/07/14 07:11 PM
brads70
Ontario,Canada
Simple answer would be to just pick up a reamer to open up the diameter to whatever dimension you want while retaining the 7* taper.
I'd have to ream the LCA which I don't think is safe to do. Not enough material there. I didn't realize the K719 screw in ball joint had the same size and taper as the stock E-Body K783 which is exactly what I needed! I have one of the Howe ones ordered to be sure.
[Re: TC@HP2]
#1682265
10/07/14 07:26 PM
10/07/14 07:26 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
I suspect Brad is chasing some pseudo Nascar application that can be adapted using common oval track parts. Since he has the machining capability in his garage, it isn't too much of a stretch for him to perform on his car. I'm anxious to see what he comes up with.
Sort of what Firm Feel had mocked up years ago, but never sold to my knowledge. He used a speedway spindle and steering arm. I think a F-body LCA or was there a C-body that had a screw in or press in lower ball joint?
[Re: autoxcuda]
#1682266
10/07/14 10:58 PM
10/07/14 10:58 PM
brads70
Ontario,Canada
I have pictures of that somewhere, Dick sent them to me after discussing some combinations for circle track. Later B-Body lowers has press in ball joints and widens the track width 1.5 per side. We run this set up on a buddys circle track car with C-Body spindles.
I just got a pair of road course spindles I'm playing around with. I'm going to modify the steering arm to use a screw in ball joint. Dimensionally they are very close to C-Body spindles, just beefier. I'll make my own hubs with the 4 1/2" bolt pattern in aluminum to shed some weight. Toying with building my own K-Frame, maybe a rack, and Schroder or speedway engineering sway bars, lots of them around cheap too. Hey, it's winter soon .... and I get bored and need a project?
[Re: brads70]
#1682268
10/08/14 02:14 AM
10/08/14 02:14 AM
autoxcuda
So Cal
...I just got a pair of road course spindles I'm playing around with....
What features would constitute a road course spindle vs a circle track spindle?
What brand spindle?
[Re: autoxcuda]
#1682269
10/08/14 11:01 AM
10/08/14 11:01 AM
brads70
Ontario,Canada
What brand spindle?
Road course spindles are symmetrical/mirror image. Oval spindles usually have different pin heights, steering arm lengths, and different KPI side to side. Optimized to turn left . I'm not sure who made these spindles? Laughlin maybe? http://www.laughlin-racing.com/productlist.asp?cid=17 The hub is from Speedway Engineering. I think these were never used at the upper levels of Nascar because the steering arm was not welded to the spindle. First time I've seen a pair that were not welded? A buddy whom I've built a few parts for used these spindles when he raced in the Hooters cup series. They usually used recycled Nascar cars/parts. At this point the only dimensions carved in stone is the upper control arm mounts and my rim tire combo/pin height ( because I just bought them(18"rims), and am not buying something different! LOL) Brake combo's , upper and lower ball joint positions, LCA pin height ( If I build my own K-Frame) front steer/rear steer, rack etc.... are all "up for review" My plan is to use a stock lower control arm and torsion bars , but the rest....? I'll have to see if I can find a different outer bearing (smaller OD) so when I make my hubs I can make the snout smaller so it fits in my wheel.
The price was right..... free so how could I go wrong?
[Re: brads70]
#1682270
10/08/14 05:20 PM
10/08/14 05:20 PM
TC@HP2
Pikes Peak Country
Wow, those sure do look like the Laughlin pieces. You may be right about that. While I'm sure the price difference is substantial, Chassisworks has come out with a fabricated spindles with bolt on steering arms among other features. http://www.cachassisworks.com/scroll down to the bottom and view the gStreet billet spindle system.
[Re: autoxcuda]
#1682273
10/08/14 09:12 PM
10/08/14 09:12 PM
brads70
Ontario,Canada
What brand spindle?
In our local Track Super Late Model division they run/allow a fab spindle like that. Also the Southwest Tour as it used to be called run a fab spindle that was two piece.
Seems like now they tend to run a welded box frame Upright. And run the bigger Wide-5 type Spindle with the two big bearings.
Similar thing around here, wide 5 or fabricated sheet metal spindles. No one uses these type of spindles as they are too heavy for the smaller short tracks around here. Before the stock stuff dried up the 2 piece Olds spindles were the hot set up on 68-72 Chevelle based front clips. Now everything is Camaro based tube chassis, bump stop stuff.... Port City is the most common chassis supplier for those that don't build there own stuff ( which is the majority, most don't build there own stuff anymore) Everything is lightweight and disposable, hence the skyrocketing cost of racing.
[Re: brads70]
#1682274
10/09/14 03:21 AM
10/09/14 03:21 AM
autoxcuda
So Cal
What brand spindle?
Most chassis here are built by 3-4 local shops. I think some cars up in Bakersfield use Port City cars or clips.
Many Late Model teams here have 18 wheeler rigs. Most Super Late (top division) have 18 wheeler rigs.
They used to do the Toyota Shootout here where short track guys would come from all over the county. Was covered on TV too. I knew a guy that had the ONLY open trailer in the pits. He finished top 4, IMHO. That was awesome!
Here's a big dollar center section the guys I know run. They ran one even more cut up, but didn't make it past 1 practice day and 1 race day practice session....
[Re: autoxcuda]
#1682275
10/09/14 04:55 PM
10/09/14 04:55 PM
brads70
Ontario,Canada
Wow that's crazy! I can see why it wouldn't last.... I did one like that for a racer years ago when the rules said no lightened gear sets. I machined pockets between the screw holes that bolted on the ring gear. Took me a lot of hours on a manual mill with a rotary table. Everything was machined with a radius, no sharp corners anywhere. The guy ran it for 4 seasons, lent it to another racer for a night and it grenade. He complained about how it didn't last very long! LOL like 2 seasons is pushing it on a gear set! He said he could feel the difference though? I think it was a 6:50 gear so the crown was really thick with lots of material removed. This was before you could buy them lightened. I've done a few gear clusters for T-10 based transmissions too. Funny how circle track stuff is all hush hush... Fun times....
