octane compression limits #1682025
10/04/14 07:49 PM
10/04/14 07:49 PM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
How much compression can be run with iron heads on pump gas in a small. Lock?
Re: octane compression limits [Re: roadrunnerreds] #1682026
10/04/14 09:25 PM
10/04/14 09:25 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
there's a lot of factors to consider. you need to start with finding out your dynamic compression ratio. usually you can get by with 92-93 octane with an 8.0:1 and lower dynamic compression ratio.
I use Wallace's website http://www.wallaceracing.com/Calculators.htm
