Page 1 of 3 1 2 3
how high can a/have you seen a 440 wind up? #1681790
10/04/14 09:42 AM
10/04/14 09:42 AM
USA MO
cdoublejj Offline OP
USA MO
how high can a 440 wind up? or how have you seen one go?
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681791
10/04/14 10:17 AM
10/04/14 10:17 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I've heard regularly into the 7 K range, but my tub runs out if steam over 6 K,and yes this " picture " is shopped
Re: how high can a/have you seen a 440 wind up? [Re: dynamite] #1681792
10/04/14 10:32 AM
10/04/14 10:32 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Used to shift our 496s at 6400 still pulling but they had a little bit of work done to them.
Careful, your character's showing!
Re: how high can a/have you seen a 440 wind up? [Re: mopar346] #1681793
10/04/14 10:38 AM
10/04/14 10:38 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
7500 with exhaust manifolds
Re: how high can a/have you seen a 440 wind up? [Re: scatpacktom] #1681794
10/04/14 10:40 AM
10/04/14 10:40 AM
mopar346 Offline
mopar346  Offline
Nice, and stock too!
Re: how high can a/have you seen a 440 wind up? [Re: scatpacktom] #1681795
10/04/14 10:46 AM
10/04/14 10:46 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I shift at 6100, and go thru the traps at 6700 to 6800... I tried shifting at RPM's up to 7000, it didn't go any faster. So, there is no sense turning it any harder than needed......
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: how high can a/have you seen a 440 wind up? [Re: Dartsport540] #1681796
10/04/14 11:31 AM
10/04/14 11:31 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I shift mine around 62 and trap around 64K
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: how high can a/have you seen a 440 wind up? [Re: 68LAR] #1681797
10/04/14 11:33 AM
10/04/14 11:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Shift at about 68.Its been higher but I dont like going much more.Rocky
Chrysler Firepower
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681798
10/04/14 11:44 AM
10/04/14 11:44 AM
Are you wanting to know about a stock type 440 or a all out wedge race motor ? If race probally around 9800, maybe a little higher depending on the heads, cam and intake My old pump gas 400 stroker 518 C.I. liked to be shifted above 7300 RPM at the track for the best performance
Re: how high can a/have you seen a 440 wind up? [Re: Cab_Burge] #1681799
10/04/14 04:52 PM
10/04/14 04:52 PM
N.Y.
sixpacksteve Offline
N.Y.
a stock 440 is about done making power at 5300 my 505 stroker has been 7300 rpm
Hell Hath No Fury Like Mine
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681800
10/04/14 09:03 PM
10/04/14 09:03 PM
AndyF Offline
AndyF  Offline
My dyno mule makes 900 hp at 7000 rpm. If it had bigger cylinder heads then it could wind higher. The rotating assembly and valvetrain are probably both good to 8000 rpm.
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681801
10/04/14 10:05 PM
10/04/14 10:05 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A lot of variables to answer the question
Stock bottom end of modified????
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681802
10/04/14 10:43 PM
10/04/14 10:43 PM
jersey
Spaceman Spiff Offline
jersey
Till just before a pushrod breaks through a rocker and comes out the valve cover....or you drive over the crank. But up to that point, you're fine...
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: how high can a/have you seen a 440 wind up? [Re: Spaceman Spiff] #1681803
10/05/14 12:15 AM
10/05/14 12:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
When Rick Ehrenberg was asked this question, he responded with something like....How high? exactly ONE rpm less than it takes to blow it up.
Re: how high can a/have you seen a 440 wind up? [Re: Kern Dog] #1681804
10/05/14 10:00 AM
10/05/14 10:00 AM
moparx Offline
moparx  Offline
or put your tach switch on "4cyl" and bury it over 10k.....
Re: how high can a/have you seen a 440 wind up? [Re: moparx] #1681805
10/05/14 11:59 AM
10/05/14 11:59 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
More information is needed to answer the question you have asked. You can Rev a motor beyond its maximum HP range and it will drop off in HP but still gain in RPM. My Race Hemi 430 CI was shifted at 9000 RPM, through the traps at 9900 RPM, making power. Good equipment is a must and good heads and cam and exhaust and intake is also a must. A 440 needs the same things, still a stock 440 motor is good to 5500 to 6400 RPM for making power depending on what 440 motor. The 440 bottom end has the same basic mathematics as a Hemi so you choice via you parts how high it can Rev.
1971 HEMI E BODY REGISTRY
Re: how high can a/have you seen a 440 wind up? [Re: cdoublejj] #1681806
10/05/14 12:59 PM
10/05/14 12:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
As mentioned depends on the build. I shift at 6400 but mine has some work. Stock 440 w/ a fresh build probably runs out of juice at 52-5400. Will it sping higher, sure but you're not making anymore power.
Coming soon!!!!
Re: how high can a/have you seen a 440 wind up? [Re: Mr.Yuck] #1681807
10/05/14 04:01 PM
10/05/14 04:01 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My max wedge shifted at 6800 traps at 7000( best et) roller cam with rev kit. Went 10,000 once when i missed second gear,shook alot of dust off bottom of car.
Re: how high can a/have you seen a 440 wind up? [Re: cudaman1969] #1681808
10/05/14 04:14 PM
10/05/14 04:14 PM
Castlegar, BC, Canada
That AMC Guy Online content
That AMC Guy  Online Content
Once at the track, my buddy missed the 2-3 shift in his Charger. He claims he pegged the tach (8k).
I'm not sure what was louder: the noise the engine made or the profanity he yelled, because we heard both.
Several weeks later we learned exactly how much damage was done.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: how high can a/have you seen a 440 wind up? [Re: That AMC Guy] #1681809
10/05/14 08:39 PM
10/05/14 08:39 PM
Maryland
gofastboater Offline
Maryland
I used to shift mine a 6000 and go thru the traps at 6200. There was a guy around me that would shift at 8500. He would go thru 3 motors a year and was WAS WAY to dumb to figure it out let alone listen to me. He owned a machine shop (that explained a lot). Ran a '70 Bee all steel 3600#. Car went 10.20's back in the early '70's.
Page 1 of 3 1 2 3
