outside rear view mirrors on race cars #1681213
10/03/14 03:24 AM
10/03/14 03:24 AM
Az
HOT IN AZ Offline OP
Az
May be a little late as my car goes to paint.... but how many of you guys still run outside rear view mirrors on your race car and why? Thanks for any replies...bye the way car is a 72 Demon with factory sport mirrors.
Re: outside rear view mirrors on race cars [Re: HOT IN AZ] #1681214
10/03/14 04:08 AM
10/03/14 04:08 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
when we had our Duster, the doors were light weight Fiberglass...no mirrors but we kept the interior mirror to aide in backing up and to see where the other guy was at...
of course my street/strip cars have rear view door mounted mirrors...I don't see a problem, and those have steel doors
Re: outside rear view mirrors on race cars [Re: smokinwoody] #1681215
10/03/14 05:41 AM
10/03/14 05:41 AM
Mississippi
Mr. T Offline
Mr. T  Offline
Mississippi
I do. It's simply a visual aid, much quicker and safer to glance in a mirror during a race than turning your head around like a owl. A bracket racer ALWAYS wants to know where his opponent is during a race.
Re: outside rear view mirrors on race cars [Re: Mr. T] #1681216
10/03/14 08:24 AM
10/03/14 08:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I took mine off. Use the rear view inside if I'm being chased. It does make it more difficult to back up though.
Doug
Re: outside rear view mirrors on race cars [Re: dvw] #1681217
10/03/14 09:33 AM
10/03/14 09:33 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Inside rear-view mirror and ebay special drivers side door mirror.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: outside rear view mirrors on race cars [Re: smokinwoody] #1681218
10/03/14 09:40 AM
10/03/14 09:40 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: outside rear view mirrors on race cars [Re: bigdad] #1681219
10/03/14 10:35 AM
10/03/14 10:35 AM
Guitar Jones Offline
I have the inside mirror on my car. I have the side mirror but for some reason I've been too lazy to install it. It's a remote mirror so it will take a little work as I want to keep that function. I guess I'll do it when I install the power windows.
Re: outside rear view mirrors on race cars [Re: smokinwoody] #1681220
10/04/14 12:33 AM
10/04/14 12:33 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Drivers side only at the moment, every ounce helps
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: outside rear view mirrors on race cars [Re: HOT IN AZ] #1681221
10/04/14 01:01 AM
10/04/14 01:01 AM
Az
Crizila Offline
Crizila  Offline
Az
Here's mine. Makes the car much more aerodynamic.
Fastest 300
Re: outside rear view mirrors on race cars [Re: Crizila] #1681222
10/04/14 01:28 AM
10/04/14 01:28 AM
Az
Az
That's more the reply I'm looking for,aerodynamics or weight. I really don't see how you can keep track of your opponent in the outside rear view mirrors. I'm leaning to removing them for the aero advantage? Again, thanks for replies.
Re: outside rear view mirrors on race cars [Re: HOT IN AZ] #1681223
10/04/14 02:01 PM
10/04/14 02:01 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Have both the passenger and drivers side mirrors. No interior rear view. The cage and switch panel are in the way on the Cuda. The 67 Belvedere will get the rear view back once I replace the headliner.
Ok
Re: outside rear view mirrors on race cars [Re: cudatom] #1681224
10/05/14 11:49 AM
10/05/14 11:49 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
on my 66 belvedere I left both outside mirrors off, its a street strip car
Re: outside rear view mirrors on race cars [Re: upnover] #1681225
10/05/14 11:54 AM
10/05/14 11:54 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
if you have one outside mirror, you need both. how do you see your opponent in the outside mirror if you only have one on the driver side door, but you're lined up in the left lane, and the driver in the right lane is faster/chasing you down?
**Photobucket sucks**
Re: outside rear view mirrors on race cars [Re: 70Cuda383] #1681226
10/05/14 12:38 PM
10/05/14 12:38 PM
norcal
JLaSalle Offline
JLaSalle  Offline
norcal
My coronets driver side only mirror comes in handy when racing faster cars and I'm in the right lane.If I'm in the left I have a better view of the faster car and can just turn around since wheel tubs etc. arent blocking my view.
Good winter excercises...loosening your neck muscles lol.
1967 Coronet R/T
9.83 134mph. 470 cid st.6 heads
10x pro et track champion
Re: outside rear view mirrors on race cars [Re: JLaSalle] #1681227
10/05/14 01:16 PM
10/05/14 01:16 PM
Richmond Twp. Mi.
Mr340 Online content
Mr340  Online Content
Richmond Twp. Mi.
in case I forget
Re: outside rear view mirrors on race cars [Re: Mr340] #1681228
10/05/14 11:26 PM
10/05/14 11:26 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I have 5" convex mirror for the passenger side. I can see pretty much anything coming up in the right lane. Funny I usually get the left lane I would say 90% of the time anyway.. My Duster had Ebay specials on both doors.
5.53 @ 125 1/8th on the launch control..more left in her!
