Re: Who else runs sliks with no tubes
[Re: MoParFish]
#1681187
10/03/14 09:03 AM
10/03/14 09:03 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
I have never run tubes, currently have 14.5x32's.
[Re: gregsdart]
#1681190
10/03/14 11:26 AM
10/03/14 11:26 AM
Posts: 1,532 off the grid
340B5
off the grid
31.5 12.5W Hoosiers, no tubes.
Nice Barracuda
Yeah, it's got a smallblock.
[Re: rickb67]
#1681191
10/03/14 11:47 AM
10/03/14 11:47 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
14 X 31 Good Year no tubes. Nice Barracuda Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: ]
#1681197
10/03/14 02:22 PM
10/03/14 02:22 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I actually ripped a tube on the street once back when I still street raced, haven't ran them since.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: Monte_Smith]
#1681198
10/03/14 02:33 PM
10/03/14 02:33 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I never understand why this debate gets so heated for some. There is really no reason NOT to run tubes. It does two things........One, it stiffens the sidewall of the tire which is generally a benefit on ANY car, but especially a heavy one.........Two, air leak issues.......GONE. I see NO downside other then the cost of the tubes
Monte
I dont see where it is a debate ? He just asked who dont run tubes and its definetly not heated. Ron
[Re: 383man]
#1681200
10/03/14 03:08 PM
10/03/14 03:08 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Monte
Maybe not in THIS thread Ron, but we have both seen it get that way. Some on this board are..........shall we say VERY passionate about their opinion and seem to get disturbed if you don't see it their way......LOL!!!
Monte
[Re: Cab_Burge]
#1681203
10/03/14 03:45 PM
10/03/14 03:45 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I've never ran tubes and don't think I know anyone that does. I agree with Monte's points about making slicks stiffer, which is good for heavy cars, and they don't leak air.
It seems to me like the slicks now days don't really leak like they used to and the manufactures seem to be making more slicks with stiff sidewalls (which are heavier and probably almost equal the weight of the slick with tubes..lol)
The main negative with running tubes for me and racing an facilities that don't have paved pits is that if you run over something you can plug your slick and keep racing (won't even miss the next round and can run them the rest of the year). If you have tubes and you run over something your done.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: rickb67]
#1681204
10/03/14 05:59 PM
10/03/14 05:59 PM
Posts: 7,506 Az
Crizila
Az
I presently run my 29" Hoosiers tubeless ( usually 11 -11.5 lbs air. I mark them to monitor the slippage - and I do get some. I rotate the tires side to side after about 10 - 15 runs. Tires are glued to the rims. That helps.
Fastest 300
