Re: Who else runs sliks with no tubes [Re: Crizila] #1681205
10/03/14 06:16 PM
10/03/14 06:16 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i've run with and without tubes both have pros and cons. for the most part i don't use them and it's not about cost.
if you have problems with severe air leakage wipe a couple coats of dish detergent on the inside before mounting.
Re: Who else runs sliks with no tubes [Re: Monte_Smith] #1681206
10/04/14 01:56 AM
10/04/14 01:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I never understand why this debate gets so heated for some. There is really no reason NOT to run tubes. It does two things........One, it stiffens the sidewall of the tire which is generally a benefit on ANY car, but especially a heavy one.........Two, air leak issues.......GONE. I see NO downside other then the cost of the tubes
Monte
I dont see where it is a debate ? He just asked who dont run tubes and its definetly not heated. Ron
Maybe not in THIS thread Ron, but we have both seen it get that way. Some on this board are..........shall we say VERY passionate about their opinion and seem to get disturbed if you don't see it their way......LOL!!!
Monte
Thats true as we have seen some heated debates on here but so far this one is not. Myself I dont care who does or does not run tubes as thats up to what that person likes. I just found the Hoosiers I use hold air all winter with no problem and being a street car I also like the fact if I get a flat I can plug it and drive on. But I am not an every weekend racer just a few times a year racer at most. Wish I could go more. Ron
Re: Who else runs sliks with no tubes [Re: 383man] #1681207
10/04/14 02:19 AM
10/04/14 02:19 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Thanks guys. Now do you still screw them or do you rotate them every so often.
Re: Who else runs sliks with no tubes [Re: slammedR/T] #1681208
10/04/14 02:32 AM
10/04/14 02:32 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I actually ripped a tube on the street once back when I still street raced, haven't ran them since.
Exactly what I was told... did not buy/use tubes with my M/T slicks. 11.5x28x15's. However, one tire retains air pressure while the other does lose pressure. I guess one out of two aint all that bad... hahaaaa Eh, after a week of just sitting, I'm not complaining.
Re: Who else runs sliks with no tubes [Re: 67dodge67] #1681209
10/04/14 03:07 AM
10/04/14 03:07 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Hoosier told us not to run tubes, and when we switched to M/T stiff sidewalls (29x10.5) we left them out. The Hoosiers held air between races, the M/T seem to loose a little.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Who else runs sliks with no tubes [Re: Dads426] #1681210
10/04/14 03:47 AM
10/04/14 03:47 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you run tubes, you MUST screw the tires to the wheels or use beadlocks. Doing neither of these is asking for a ripped out valve stem. Of course in my opinion screws are a MUST with slicks period, but plenty will be along shortly to tell me I am wrong.........LOL!!!
Monte
Re: Who else runs sliks with no tubes [Re: Monte_Smith] #1681211
10/04/14 10:25 AM
10/04/14 10:25 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We run tubes, seems to help on the normal slicks we've run now and in the past. We've also tried slicks with stiff sidewalls and tubes, the notes we made says we went slower in the 60ft.
Oh and we run rim screws 16 a side (32 per wheel)because I just cant afford beadlock rims
Re: Who else runs sliks with no tubes [Re: Monte_Smith] #1681212
10/04/14 12:29 PM
10/04/14 12:29 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Monte
MY car with 29.5 10.5 micky non stiff is a couple hun faster with tubes
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
