pulling hemi from ram #1680929
10/02/14 12:13 PM
10/02/14 12:13 PM
massachusetts
X
xs29l9g Offline OP
xs29l9g  Offline OP
X
massachusetts
yeah...sounds like a stupid question,but does anyone have any tips on best way to attach a cherry picker chain to a hemi to pull. no sizeable bolt holes to use. I can likely wrap chain around front accessory bracket,but not much options at rear of engine. book and dealer says pull intake and use special plate with intake bolts. 2 concerns with that, 1st haven't located a plate, 2nd 10 6mm bolts in aluminum sounds like potential trouble. any thoughts out there appreciated. thanks gregg
Re: pulling hemi from ram [Re: xs29l9g] #1680930
10/02/14 01:16 PM
10/02/14 01:16 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
You could always use the old seatbelt trick, but rest assured people have been doing heart transplants forever with the old intake plate that looks like a set of brass knuckles without any problems.
Re: pulling hemi from ram [Re: moparjim79] #1680931
10/02/14 01:24 PM
10/02/14 01:24 PM
dogdays Offline
dogdays  Offline
And if the new Hemi had a carburetor that one could unbolt, that'd probably work.
Maybe pulling the intake manifold now is the best way to go.
The whole engine doesn't weigh as much as a LA motor, it's like 100lb lighter. That may make it easier to find sufficient strength. Four 5/16" (8mm) bolts in tension will support it many times over. Heck, one could probably go to 6mm bolts (1/4").
Somewhere yesterday on this board I saw a picture of a lifting bracket that attached at the exhaust manifold bolts.
I hope someone has a better answer than this one.
R.
Re: pulling hemi from ram [Re: dogdays] #1680932
10/02/14 01:34 PM
10/02/14 01:34 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I'm fully aware the new 5.7s are not a carbed deal, the reference was only to put mind at ease as far as the method of attaching and the weight involved. And picking it up by the manifold attaching points is a good idea as well, alls that would be needed there is some high tensile steel cord and 4 angled brackets to lift the whole shooting match.
Re: pulling hemi from ram [Re: moparjim79] #1680933
10/02/14 02:48 PM
10/02/14 02:48 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
i know when pulling a hemi from a car the dealer uses a fixture that bolts to the front and rear of the motor
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: pulling hemi from ram [Re: Savoy1964] #1680934
10/02/14 08:56 PM
10/02/14 08:56 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
When they manufactured that truck it went in from the bottom. If its a 2X4 you might take a look at doing that. I don't think I'd try iy on a 4X4.
Re: pulling hemi from ram [Re: Cudajon] #1680935
10/02/14 09:07 PM
10/02/14 09:07 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Not quite. The powertrian is bolted onto the chassis and then the body is dropped over top. There is no way to drop it out the bottom due to at least 2 welded crossmembers.
The easiest/best way is to get the special brackets the dealer should have. Another possibility is to pop the cab off if you have access to a 2 post lift. It;s only about 8 more bolts and a couple other wire harnesses and makes it real easy.
Re: pulling hemi from ram [Re: 73MagDuster] #1680936
10/03/14 12:51 AM
10/03/14 12:51 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The best way to pull the engine is of course with the special tool from miller. It can be pulled without it just as easy. You must remove the intake to remove the engine with or without the tool. the rear attachment point of the tool in the center of the lifter valley can be used to bolt a chain in a loop. There the chain can be attached to the engine with 2 8mm bolts threaded into iron block. Plenty strong enough to lift the engine out of the truck. I have done it this way several times without a hitch.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
