Re: 1999 Ram Idle Control System Malfunction P0505
[Re: Dartslantsix]
#1680812
10/02/14 02:24 AM
10/02/14 02:24 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Since it's a jobber part, it's most likely the problem.
There was a jobber camshaft position sensor in our '04 Neon when we bought it, and same as yours: it worked great for a year or so, and then the code showed up. I put a Mopar one in and haven't had a problem since.
I'd advise to go back to a Mopar part. There just is no room for aftermarket sloppy calibration when it comes to todays' fine-tuned computers.
When the OEM ones give issues just clean them with brake cleaner and they last a fairly long time.
The idle in my '01 Ram started to fluctuate a little, I cleaned it, and it's been good for over 200,000 miles.
Mo' Farts
Moderated by "tbagger".
[Re: Dartslantsix]
#1680814
10/03/14 01:10 AM
10/03/14 01:10 AM
Posts: 6,480 Kingston, IL USA!
gts340swinger
Kingston, IL USA!
I had a 99 Ram with a 360 in it. If I let the truck sit for a week or longer it would sometimes idle high for awhile until it warmed up or sometimes even longer. I would just spray out the throttle body and it would fix the problem for awhile. I really think it had something to do with the ethanol in the fuel gumming up. If I drove it daily, I never had a problem.
Mr. Norm's "Fanatic" (idiot) 71 Mr. Norm's Demon GSS 77 Mr. Norm's personal B250 GSS van 76 Mr. Norm's KZ900 Motor Sports Special 69 Mr. Norm's M code Dart GTS 69 D100 68 Barracuda 64 Valiant V200 07 Charger Daytona SST 6 speed test mule.
[Re: J_BODY]
#1680816
10/03/14 05:34 AM
10/03/14 05:34 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Pick up a couple good factory ones from Pick & Pull or whatever the recycling yards are called by your place.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Dartslantsix]
#1680817
10/03/14 11:15 AM
10/03/14 11:15 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
While you are at it, get a spray can of Berrymans B12 and an old toothbrush and clean your throttle body. There will be a buildup of crud around the throttle plates, IAC motor seat and some other areas that cause funky idle issues.
Carl Kessel
