Page 1 of 3 1 2 3
Four link and mini-tub advice... #1680660
10/01/14 02:26 PM
10/01/14 02:26 PM
MN
ryangtogtx Offline OP
MN
I'm looking for input for my dad. He wants to mini-tub and put a four link in his '63 Dodge MW. Any advice or pictures would be greatly appreciated. Thanks.
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680661
10/01/14 02:31 PM
10/01/14 02:31 PM
MN
MN
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680662
10/01/14 09:30 PM
10/01/14 09:30 PM
Penna
70satelliteguy Offline
Penna
"Any advice or pictures would be greatly appreciated. Thanks. "
Don't have any advise but your shop is impressive
I believe you could eat off of the floor
Mike
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680663
10/01/14 11:22 PM
10/01/14 11:22 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
The four link may interfere with street exhaust routing.
That is keeping me with leaf springs.
Re: Four link and mini-tub advice... [Re: NTOLERANCE] #1680664
10/01/14 11:29 PM
10/01/14 11:29 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The nature of a four link install almost makes a full on tub job make more sense.
It could certainly be done , but to get optimum length bars and angles I think the back seat is a goner.......and as long as you are in that deep , why not stuff some meat back there.
I am wrestling with that decision for my A body and the least painful would be ladder bars.
I will exhaust a bit more effort on the leafs , but getting them to hook consistently is looking like a problem.
If I do go four link , I will also go big tire.
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680665
10/02/14 10:17 AM
10/02/14 10:17 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Not as adjustable as a full 4 link but better than a ladder bar.
Re: Four link and mini-tub advice... [Re: GTS340] #1680666
10/02/14 10:18 AM
10/02/14 10:18 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Fits under most stock floors too. Called Ultralink and made by Hodges racecars, not sure if they are still around but any decent fabricator could make one.
Re: Four link and mini-tub advice... [Re: GTS340] #1680667
10/02/14 04:12 PM
10/02/14 04:12 PM
K
Kiddart Offline
Kiddart  Offline
K
that looks like the best of both worlds. Have you made any passes with it yet?
Thank you
Kiddart
Re: Four link and mini-tub advice... [Re: Kiddart] #1680668
10/02/14 04:47 PM
10/02/14 04:47 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Not my car, just random internet pics. I plan to use this set-up on my Dakota. A few people on YB think rather highly of the Ultralink. It was appealing to me, takes about the same amount of real estate as a ladder bar but offers more adjustment options, more could be had by redesigning the brackets.
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680669
10/02/14 06:42 PM
10/02/14 06:42 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
mine is a little more than maybe what you want to do..4-link, coil over, 4 point anti-roll, frame and will have 40" tubs
take your time
Re: Four link and mini-tub advice... [Re: smokinwoody] #1680670
10/02/14 06:44 PM
10/02/14 06:44 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
pic
Re: Four link and mini-tub advice... [Re: smokinwoody] #1680671
10/02/14 06:45 PM
10/02/14 06:45 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
it's a 63 Dodge MW..
Re: Four link and mini-tub advice... [Re: smokinwoody] #1680672
10/02/14 08:24 PM
10/02/14 08:24 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
it's a 65 Dodge MW..
isn't that a picture of a 63 dodge??
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680673
10/02/14 10:15 PM
10/02/14 10:15 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I'm assuming this is mainly a street car. Why not Mini-Tub and leaf springs? Works well on the street and good for low 10 second ET's. Ladder bars work excellent in this venue but aren't as street friendly. But they would allow you to keep the back seat.
Doug
Re: Four link and mini-tub advice... [Re: old_racer] #1680674
10/03/14 04:00 AM
10/03/14 04:00 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
sorry, Typo...yes 63
by the way, this car will see mostly street duty and an occasional trip down the strip...the engine is a 499 rebuilt to run on 93 pump gas ..big HP and torque..shouldn't weigh more than 2800lbs due to acid dipped fenders and doors and being completely gutted..plus the use of Chrome Moly Steel for cage, suspension and other structural pieces...
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680675
10/03/14 04:02 AM
10/03/14 04:02 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
have fun with your project....great way for Father and Son bonding!!
Re: Four link and mini-tub advice... [Re: ryangtogtx] #1680676
10/03/14 03:05 PM
10/03/14 03:05 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Unless it is going to be 80% race car, I would go with the mini tubs and cal-tracs. A four link will take away some of the streetability.
Yes a 4-link can be driven on the street, but for the slight ajustability advantage, it may not be worth sacrificing the better ride of the leaf springs.
Re: Four link and mini-tub advice... [Re: ProStDodge] #1680677
10/03/14 05:41 PM
10/03/14 05:41 PM
MN
MN
Thanks for all of the input. Good food for thought.
Re: Four link and mini-tub advice... [Re: ProStDodge] #1680678
10/03/14 09:35 PM
10/03/14 09:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A consideration for a "street car" is a triangulated 4 link, similar to a G body or a Mustang. I actually have that under a Challenger. I used Mustang type arms with urethane ends and the end can turn. Built custom brackets. The triangulated bar eliminate the need for a locator or a wishbone. With a good shock, the ride is 10 times better than buggy springs and at the track, a 4 bar is a 4 bar
Monte
Re: Four link and mini-tub advice... [Re: GTS340] #1680679
10/04/14 09:17 PM
10/04/14 09:17 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I went from a ladder bar to this ultra link system and love it.I have been running it in my dart for probably 7 years now.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Page 1 of 3 1 2 3
