Re: 5 or 6 speed options?
[Re: OzHemi]
#1680591
10/02/14 04:19 AM
10/02/14 04:19 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
What about just getting a common, GM F body T56 six speed and use a quicktime bellhousing?
You want cheap and a manual, that's probably the way to go. I believe they handle up to 450 ft lbs too.
[Re: Lmopar69]
#1680595
10/05/14 11:56 PM
10/05/14 11:56 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Need to know more about your build and your intended useage for the truck and trans.
I was going to swap a 6 speed Dakota trans into my sb truck before. Do not exactly remember the ratios but they were not ideal for a hot rod truck.
Did the NV3500 instead. Only because of cost and ease of swap. It came from a small block so: Correct bellhousing, it came with a usable flywheel, speedometer cable and output yoke. Cons. I hated the 4:1 first gear and 2nd was a bit tall for takeoff from a dead stop. It's a wide ratio truck trans, made for weak engines in heavy trucks. Pros Absolutely loved the syncronized reverse, shift quality was on par with any modern car. It made my truck 3mph faster in the 1/4 mile. Tells me compared to a 518, it's more efficient. Same for the MPG. Gain was around 2mpg over a 518 auto.
The T56. Super tough transmission. Best shifting trans out there, better than a 833, TKO 500 or 600. It will take an expensive swap kit to install it into a Mopar and you are not doing it for under $3000. Pros, best gear ratios over any other manual trans we've talked about here.
[Re: Lmopar69]
#1680596
10/06/14 12:14 AM
10/06/14 12:14 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I guess I'll start looking for a donor car then. Too bad I cand find a trans out of a Mopar.
It's practically the same thing you'd get out of a Viper T56 except for some minor changes here and there.
[Re: MuuMuu101]
#1680597
10/06/14 12:50 AM
10/06/14 12:50 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I love my T56.
Mines out of a 3rd gen viper but inside, the only difference in a viper unit is the input shaft (easy to swap) and the main shaft has a bigger tail end. All the bearings, gears, syncros, and case are identical.
**Photobucket sucks**
[Re: 70Cuda383]
#1680598
10/06/14 12:52 AM
10/06/14 12:52 AM
70Cuda383
Marysville, O-H-I-O
There is a nv3500 option that has a 3.48:1 first. Much better than the 4:1 units, and not that bad with a 3.91 rear gear and 28" tires. If running 26" tires, I'd go for a 3.7x rear gear if possible
[Re: 70Cuda383]
#1680599
10/09/14 09:36 PM
10/09/14 09:36 PM
Magnum
70Cuda, where would one find the 3.5:1 first geared NV3500. I've found a 4:0 in a 94 V6 1500, another one in a 95 5.2L 1500 and bought a brand new over the counter 1996 NV3500. All 4:1
[Re: Magnum]
#1680600
10/10/14 01:04 AM
10/10/14 01:04 AM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
If I'm not mistaken, Magnum, the only source is a 2nd Gen, 2 wheel-drive, 3/4 ton truck with a 360. Yep, goooooood luck finding one of those.
Mo' Farts
Moderated by "tbagger".
