Duster vs Scamp weight #1680575
10/01/14 11:06 AM
10/01/14 11:06 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Anyone know the weight difference between a Duster and a Scamp? If your comparing the same model and drivetrain in each, how much weight difference is there between the 2?
Re: Duster vs Scamp weight [Re: DusterKid] #1680576
10/01/14 12:11 PM
10/01/14 12:11 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
NHRA says a 71 Scamp 318 is 4 pounds heavier than a 71 Duster with a 318. 2884 shipping on the Scamp, 2880 shipping on the Duster.
Re: Duster vs Scamp weight [Re: John Brown] #1680577
10/01/14 11:06 PM
10/01/14 11:06 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The Scamp has an 111" wheelbase as compared to 108" for the Duster/Demon/Dart Sport. I'd expect the Scamp/Dart to pack more than 4 pounds over. The roofline of the Scamp/Dart is wider and longer which certainly adds weight. The floorpan is longer, the drive shaft is longer, fuel and brake lines too. The Scamp/Dart has roll up rear windows as opposed to simple pop outs on the Duster. I'd be surprised if the Scamp wasn't at least 50 lbs heavier.
Re: Duster vs Scamp weight [Re: Kern Dog] #1680578
10/01/14 11:49 PM
10/01/14 11:49 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Go to nhraracer.com then to Stock Car Classification on the left side under the Tech area. Click on Plymouth 1971 open the PDF file and scan down to line 253 and 255. Scan over to the right and read the weights under the engines with the single * . That is for the stock class cars. Note that the 340 Duster weighs 274 pounds more than the 318 Duster. I can't explain that either but I don't know any other way to find the weight online. As an aside, they show a similar Demon at 2884 and the Dart Swinger at 2893.
Re: Duster vs Scamp weight [Re: John Brown] #1680579
10/01/14 11:58 PM
10/01/14 11:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Duster vs Scamp weight [Re: John Brown] #1680580
10/01/14 11:59 PM
10/01/14 11:59 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I am not saying that you are personally wrong, just that I doubt the accuracy of your source. I may be wrong.
Re: Duster vs Scamp weight [Re: John Brown] #1680581
10/02/14 12:00 AM
10/02/14 12:00 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
340 car would have a 727, 318 would have a 904. 340 would have an 8.75 rear, Standard trans 318 also has an 8.75. 318 auto has a 7.25. 340 car also has a beefier spring pack. Even so, 274 pounds sounds like a lot.
Re: Duster vs Scamp weight [Re: forphorty] #1680582
10/02/14 12:13 AM
10/02/14 12:13 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Intake manifold, 4-bbl carb, exhaust manifolds, dual exhaust, wheels/tires/spare, and plenty of other heavier parts on a 340 as compared to a 318.
JB Rhinehart, Realist
A-Body's RULE!
Re: Duster vs Scamp weight [Re: Rhinodart] #1680583
10/02/14 12:40 AM
10/02/14 12:40 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
71 Spec both with v8
Duster 3005
Scamp 3070
http://www.hamtramck-historical.com/imag...ng_specs_18.jpg
Re: Duster vs Scamp weight [Re: RobX4406] #1680584
10/02/14 09:59 AM
10/02/14 09:59 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
I have a 71 scamp and a 71 duster.
The 71 scamp has fiberglass bumpers, hood, seats, a 360 w/aluminum intake, and headers with short exhaust.
The 71 duster has an all cast iron motor, full exhaust, all steel exterior and a full interior with a roll bar and subframe connectors. The duster is still 220lbs lighter.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: Duster vs Scamp weight [Re: RobX4406] #1680585
10/02/14 03:28 PM
10/02/14 03:28 PM
When looking at NHRA weights you need to keep in mind that NHRA "factors" in horsepower on certain cars and not on others so the "factored weight" will be different than the actual factory shipping wieghts if that cars motor has been factored, which 340 have been heavily factored for a long time especially the 1971-73 340 and 1970 340 6 pak Challengers
Re: Duster vs Scamp weight [Re: F1Scamp] #1680586
10/02/14 03:30 PM
10/02/14 03:30 PM
The Scratch, WA
P
Part_Stalker Offline
P
The Scratch, WA
The closest I could come was from a July 2000 article in HP Mopar magazine on power to weight ratios. Says a 1970 340 Dart is 3179 while a 1970 340 Duster is 3110.
Re: Duster vs Scamp weight [Re: Part_Stalker] #1680587
10/02/14 04:01 PM
10/02/14 04:01 PM
Keymar, MD
Keymar, MD
Thanks for all the replies guys.
