converted Reid bell to R5
#1680392
09/30/14 07:57 PM
09/30/14 07:57 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Tons of work and out .020". Hemi starter pocket had to be removed and welded up. Save your time and order a browell or just use an adapter.
Re: converted Reid bell to R5
[Re: LSP]
#1680394
09/30/14 10:04 PM
09/30/14 10:04 PM
Leon441
Lynchburg, VA
I prefer Bobsprofab. I made some small changes for my bell uses the 12 o'clock bolt hole. I trimmed some fat also. Would like to duplicate what I have at local shop. And send program to Bob for reference.
[Re: Leon441]
#1680395
10/02/14 01:32 PM
10/02/14 01:32 PM
Leon441
Lynchburg, VA
My time and efforts turned out to maybe no be a waste. Been contacted about a production of bells to go from R5 to Reid transmission cases. Use Mopar starter. Next step is a simple flywheel with no adapters.
This will be a game changer as this bell will be cheaper than current adapters.
[Re: Triple Threat]
#1680397
10/05/14 11:20 AM
10/05/14 11:20 AM
Leon441
Lynchburg, VA
These should be priced the same as other quick time bells. Nippondenso staters are fine. The flywheel will also be available. I already have 5 spoken for with a small R5 dealer.
Any Reid glide or T400 case will work.
So who's interested? The more I can order the faster and cheaper.
Leon
[Re: Leon441]
#1680398
10/16/14 10:32 PM
10/16/14 10:32 PM
Leon441
Lynchburg, VA
The design guy at quick time says there will be other possibilities with this bell. Basically a lot of options like Ford trans some street rodders are using. Also could be made to bolt to pump bolts on a torqueflite with the bell cut off.
The flywheel should be done the same time as bell shortly after SEMA.
