E body steering wheel #1680384
09/30/14 06:51 PM
09/30/14 06:51 PM
Dr Dave Offline OP
Dr Dave  Offline OP
What are some cool looking steering wheels with a Pro Touring look that people are using that work on a stock E body column?
Re: E body steering wheel [Re: Dr Dave] #1680385
09/30/14 06:53 PM
09/30/14 06:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What do you call a pro touring look?
Re: E body steering wheel [Re: Dr Dave] #1680386
09/30/14 10:32 PM
09/30/14 10:32 PM
IMGTX Offline
IMGTX  Offline
I used a Grant 4 spoke with the grant adapter instead of the accordion can on my car.
To compensate for the shorter column I used an A/B body turn signal lever because the E body one was too close to the wheel.
Re: E body steering wheel [Re: stumpy] #1680387
10/02/14 02:50 AM
10/02/14 02:50 AM
Dr Dave Offline OP
Dr Dave  Offline OP
I suppose anything that looks more modern and performasnce oriented like the Tuff wheel. It sounds like anything can be used with a standard adaptor as long as you don't use the "can" and you modify the turn signal arm, correct??
Re: E body steering wheel [Re: Dr Dave] #1680388
10/06/14 01:16 PM
10/06/14 01:16 PM
IMGTX Offline
IMGTX  Offline
You can modify the arm or get one from just about any A/B body. Probably C body, Trucks too.
I liked the 4 spoke grant but it did cover my Speedo and tach. Getting a larger diameter wheel like the factory had would fix that but I like the look and feel of the 14" wheel.
