Recommend me and Intake and Carb! #1680359
09/30/14 04:51 PM
09/30/14 04:51 PM
Goodyear Arizona
midnite360 Offline OP
Goodyear Arizona
Just Scored a 5.9 Magnum out of a 98 Ram 1500. plan on doing the Carb conversion. Going to run the stock bottom end and stock heads along with the 5.9 Roller Whiplash from Hughes. In keeping with the stock heads what intake would you guys recommend and also what size carb would be best? It is going in a 1977 Shorty Stepside
Re: Recommend me and Intake and Carb! [Re: midnite360] #1680360
09/30/14 08:41 PM
09/30/14 08:41 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
Edelbrock RPM Air Gap (for the magnum heads) & 650-750 CFM 4bbl Holley should pull plenty of air into that 5.9
Re: Recommend me and Intake and Carb! [Re: 98RAM1500] #1680361
09/30/14 09:38 PM
09/30/14 09:38 PM
scratchnfotraction Offline
airgap with a holley carb
Re: Recommend me and Intake and Carb! [Re: scratchnfotraction] #1680362
10/01/14 01:38 AM
10/01/14 01:38 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Spend the extra $$$ if you want
Gasket match this, flow more & fit better
I used this intake on a stock Magnum with a 650 spreadbore double pumper on my CrewCab & could light the tires easily 33's with 4.11's
Really it all depends on what front that you go with LA or Magnum
The Edelbrock fits best with the Magnum front
The Crosswinds fits best with the LA front
I own & use both of them
Re: Recommend me and Intake and Carb! [Re: BulletBob] #1680363
10/01/14 02:08 PM
10/01/14 02:08 PM
Goodyear Arizona
Goodyear Arizona
Thanks for the input. Looks like an Airgap of some type is the logical choice. Carb I'm still undecided on which size to go with.
Re: Recommend me and Intake and Carb! [Re: midnite360] #1680364
10/01/14 05:03 PM
10/01/14 05:03 PM
dogdays Offline
dogdays  Offline
750 Street Demon should be a really good fit on that engine.
One of the Holley 750 vac secondary carbs would also be in the running, like 80508 or 3310.
R.
Re: Recommend me and Intake and Carb! [Re: dogdays] #1680365
10/01/14 05:21 PM
10/01/14 05:21 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
R.
one with a hotter cam can use a 750 easy
Re: Recommend me and Intake and Carb! [Re: BulletBob] #1680366
10/01/14 08:38 PM
10/01/14 08:38 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
Bulletbob sezzzzzz...."I used this intake on a stock Magnum with a 650 spreadbore double pumper on my CrewCab & could light the tires easily 33's with 4.11's"
Hey bob have you driven this truck mentioned above enough to establish any type of gas mileage figure ? and or have you done any towing with it ?
just curious as i have something similiar in mind ......
Re: Recommend me and Intake and Carb! [Re: ChinooK440] #1680367
10/01/14 09:15 PM
10/01/14 09:15 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
It's maiden voyage without any real tweaking on the carb (12 hrs after I fired it up & bled the brakes)was a 1800 mile trek with 6 in the cab.
It got 16 mpg towing my 1987 Grand National back home
6 months later I did a 600 Holley for it, put a 31" A/T tire took off the FlowMaster & put a new CTD muffler for a 2008 model & squeezed 19-20 MPG hwy @ 70 MPH
My CrewCab has a 518 trans & I was switching it by the reading on the speedo
It has never been weak but the tire smoking changed with the smaller carb
I have over 65K on it since the swap & I'm getting ready to put a RC floor & newer firewall in it now
Re: Recommend me and Intake and Carb! [Re: BulletBob] #1680368
10/02/14 10:30 AM
10/02/14 10:30 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
16 mpg towing a G.N. with 6 people on board ? .... was that trip all down hill or what ?
Re: Recommend me and Intake and Carb! [Re: ChinooK440] #1680369
10/02/14 03:24 PM
10/02/14 03:24 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
No that was going north on I55 driving 65 mph
